ABS/VDC/Slip lights on. Low clutch fluid?
Hey guys,
I noticed a couple of days after i mounted my new wheels on that all three of the above lights kept coming on, and staying on. I thought maybe because of the new setup and camber it might have triggered something, but then after driving for a little bit I noticed a faint smell of almost a burning plastic. So i looked up a bunch of threads of other G's having the same lights on and I saw that it could be a number of things; low brake fluid, MAF sensor, and a couple other things. I checked the brake fluid and its in between the Max-min so Im prety sure thats not effecting it, but then when I looked at the reservoir next to the brake fluid, its below the min. Im assuming thats the clutch fluid reservoir? If so, do I just add more brake fluid? I chcked the manual and it says to add the same brake fluid to both reservoirs. Any help would be much appreciated.
Thanks!
Thanks!
well, clutch fluid added, but all the same lights are on, and I still get a slight burning plastic smell. Forgot to say that the service engine light went on about 2 days before the new wheels went on. Will probably just try to set something up at a dealer so they can take a look at it. Info is still welcome though!
This is why I resist adding aftermarket stuff. I love working on cars but they've gotten so bloody complicated even something as simple as new wheels can throw something off.
Good luck with this, and please let us know what the dealer says...
yeah i know, a friend of mine with an is250 said the same lights went on for him as well when he put on his vossens, but ive had 10.5" wide 20s on for a over a year with no problem, now with an 11" setup it creates a **** show? loll i dont get it. especially the plasticy smell
i have a 08 G37s and i just upgraded my tires. fronts to 245/40/19 and rear to 275/35/19. pulled it outer the shop drove about 300 yards and slip light came on and wouldn't let me accelerate. tired it again same thing. pushed the VDC button and i am driving back to normal. any idea whats going on here?
please help
please help
Cr0tchf4i
08-19-2015 03:52 PM
Badgerman
08-19-2015 02:26 PM
