Pulled the trigger on Swift Springs and Konis today!
Well bad news. Got the swift springs and Koni fronts installed and the top of the wheel arch is 29.5" Ahhhhh! Can you think of anything that I am doing wrong in the install? the car drives fine. except that the front is now 1.8 inches higher than the rear.
I was hoping for 27" wheel arch height.
So Antirice's suspicions were correct.
I am thinking about swapping the Koni's back out for the Infiniti dampers, but I really wanted adjustable dampers. Feeling regretful and stupid that I didn't buy the BC coil-over's now.
Front Swift + Koni's
Rear Stock Infiniti OEM for comparison
Nice. Let us know if the Koni actually raise the height of your car.
I think I know what happened. I installed the bottom spring seat upside down. I have been mulling this problem for a couple of days as I finished the install on Saturday nite. Monday morning around 9AM it came to me. The bottom seat can be installed in the up or down position. I have it reversed. When I get back to my garage I will redo the install, take pictures document the process and the results. But I expect that flipping over the seat will correct the problem.
Yeah, I am going to redo the install tonight and will post pics of struts and final result.
Good thing I have a 17 y/o son to help me!
The great thing about DIY, is that by the third time I redo the work, I have learned everything I need to know to do it right the first time!
This is the final, correct result. Yea! Finally got it right. For a 26 7/8" wheel arch height.
<a href="http://s215.photobucket.com/user/ssscottg/media/20130716_203732_zpsee5c309f.jpg.html" target="_blank"><img src="http://i215.photobucket.com/albums/cc93/ssscottg/20130716_203732_zpsee5c309f.jpg" border="0" alt=" photo 20130716_203732_zpsee5c309f.jpg"/></a>
This is the incorrect way to assemble the coilovers.
<a href="http://s215.photobucket.com/user/ssscottg/media/20130716_182205_zps4801e2e3.jpg.html" target="_blank"><img src="http://i215.photobucket.com/albums/cc93/ssscottg/20130716_182205_zps4801e2e3.jpg" border="0" alt=" photo 20130716_182205_zps4801e2e3.jpg"/></a>
This is the correct way to assemble the coilovers.
<a href="http://s215.photobucket.com/user/ssscottg/media/20130716_184424_zps07a98c26.jpg.html" target="_blank"><img src="http://i215.photobucket.com/albums/cc93/ssscottg/20130716_184424_zps07a98c26.jpg" border="0" alt=" photo 20130716_184424_zps07a98c26.jpg"/></a>
The bottom of the shock is 120 f/lbs I think it's called the end link.
the top of the shock is 3 x 28 f/lbs (where it goes through to the engine compartment)
These are the key values from the 2012 G37 service manual.
#30
