cut or buy new rotors?
guys dealer states they cut rotors and replace pads was told they cut rotors up to 2 times before needed replacing. why do you sugest buy or resurface them rotors have not been cut before
I was very happy with the work and I was due for another pad replacement last August with 171796 miles on those pads on my G35.
Rather than spend the money for brake replacement and a few other items I decided to trade it in for a new 2012 G37S
Bottom line, I got good mileage out of the OEM pads and good mileage out of the dealer replaced pads.
I'm an old farht and what I've learned over my many years of driving and owning many vehicles is that I only trust the dealer to work on my cars.
I also request that only the top most experienced factory trained technician do any work on my vehicle.
I get my New Jersey $130 hourly labor charge moneys worth with excellent top quality work.
Having said all that, In order for the dealer to guarantee their work that is the factory recommended procedure.
Keep in mind your life depends on brakes and tires.
Would you rather trust this work to some inexperienced kid to save a few bucks?
Good luck in your decision
Telcoman
![](/images/staff.gif)
There are some things that a dealership's Service Department can be more efficient with, because of corporate training certifications and having done the identical work on the identical cars over and over. However, that really only applies to the senior mechanics... and of those, only the ones who still give a fck.
Here's my advice about brakes, (from another old farht who's only months away from the big Five-O):
- Aftermarket performance parts are superior to OEM.
- A good mechanic will do just as good a job as the dealership on brakes, if not better.
- The differential in cost is a HUGE savings over OEM parts and Dealer-installation, potentially half as much.
- You will end up with a better quality brake system.
quakerroatmeal (06-27-2013)
And of all things to work on, brakes are just about the simplest, and least difficult to **** up.
![Roll Eyes (Sarcastic)](https://www.myg37.com/forums/images/smilies/rolleyes.gif)
Personally, I hate it. I wish it were an actual emergency brake. If I had a dollar for every time I approached a speed trap and my hand instinctively pulled up on the brake handle, then went "Doh!" realizing it wasn't an actual, proper e-brake...
All that means is that you didn't put the effort into finding a respected street/pro mechanic that you could build a trusted relationship with. That also tells me that you don't engage mechanics to modify your car with non-OEM parts, so you either do that stuff yourself, or not at all.
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
Good points John, all of them.
drizzy315 (06-28-2013)
nothing wrong with cutting ( turning) rotors as long as they are within spec.
I had mine turned at around 40K miles and they stop as good as they did when I bought the car.
I worked at a parts store while I was in college. We turned around 20 sets of rotors a week. Never had any issues.
OP - if your rotors are within specs (i.e. not too thin) go ahead and have them turned (cut) when you have the pads replaced. rotors are often good for at least one turning.
i couldn't agree more with the above posts referencing high-quality and reputable independent shops being excellent alternatives to the dealership. especially when it comes to routine maintenance items like brakes and alike. many long-time Nissan/Infiniti technicians start their own businesses and are extremely competent at their craft. many of these shops will allow you to provide your own parts too, which multiplies the savings! buying parts at the dealer and having the work done by the dealer is just nuts, IMO.
of course, DIY is always a great idea if one has the means to do the straight forward jobs.
as long as you keep your records and receipts, you are covered for warranty claims.
and yes, many premium aftermarket brands surpass OE parts in terms of performance/wear characteristics and value. OE stuff will always work, of course, but aftermarket is often better.
Rochester really great post.
Telcoman you're fooling yourself if you think the dealership is the best. Have you ever been back to the bay? I've recently went to Infiniti and I always look at who's working on my car etc. Nothing but 18-19 yr old kids working on the cars back there. Nothing impressive @ 130$/hr. Just rape prices for consumers who does not know any better pays for it.
I for one prefer OEM pads. Even though they cause a ton of dust..I just like the feel. Most (not saying all) after market pads lose initial bite which I don't like.
I always buy new. Have had rotors cut a few times (on Acuras) and they all warped. That being said I have a cut pair of rotors on my 09 G right now (had been cut right before I purchased the car) and they have been great.
The main reason I don't cut is because I don't typically have time to wait a day or two to have it done. I suppose I could buy a new set for immediate replacement and then I would have years to get the used set cut. Since it takes me 60-70k to wear through a set of pads/rotors, I'm not too worried about it and I don't want rotors sitting in my garage for years.
brian
brian
Very interesting - thanks for sharing. I should rephrase --- on the Aucras, I experienced Judder -- way past the point of annoyance and into dangerous territory. I must admit I did not follow a proper break in procedure and at the time I did not own a torque wrench so who knows what could have happened.
On my previous infiniti (new rotors each time), I did follow the burnishing procedure in the service manual and experienced long life with OEM (kiriu rotors) and Akebono Ceramic pads.
Brian
Brian
It really is interesting, isn't it? Thanks, monty.
One of the little tricks that my mechanic does after bedding in new brakes is to immediately shoot the rotors with an IR Gun, to verify that the brakes are being applied with relative pressure on both sides. In my entire life, I've never seen anyone do that before, although it makes some sense.
