Brakes for the street and track
Hello everyone! Thanks in advanced for the help!
I've been on the track twice with my 2011 G37s and both times I've experienced pretty bad brake fade. My next track weekend is May 18 and I'm already planning on getting power slot rotors for the front axle. I still am using my stock pads, as my car only has about 10,000 miles. My question is, will the slotted brakes in the front be enough to prevent brake fade? Is it absolutely necessary to get performance pads?
I love driving on the track, as it is the one time I can really explore the G's true potential. And my day is always partially ruined by pretty scary fade. It would be great to get this working well so I can track the car for the entire day!
Thanks again for everyone's help and input...I hope I'm not putting up a repeat thread because I've looked all over for this info!!
Blnewt thanks for that advice. You just answered the question I was just going to ask. I've heard 'mostly' good things about Hawk, so I think I will stick with them. Question is would the hp plus be too extreme? I'm not worried about lots of brake dust or the occasional squeal....
A track set of pads is paramount, but will do nothing if not bedded in properly.
As mike said, HPS for light track/DD and HP plus for heavy track will work well. Another comparable set are the EBC series...yellow for the light track/DD and red for heavy track.
As for drilled, slotted, and drilled/slotted there's mixed feelings. These rotors, in theory, help with cooling the rotor. In reality, they don't. The only thing good about a good set of quality 2 piece drilled rotors are the weight savings. The slotted rotors help carry dust away from the braking area, and drilled/slotted have a little of both, but they honestly degrade the integrity of the rotor for track purposes.
My advice, get yourself a nice set of regular rotors...not sure if oem counts because of some of the problems known to happen. Betty is right, a set of track rotors/pads only used at the track. It would help not having to clear the brake compound from the rotors every time you want to go to the track...would be easier to just change pads and rotors.
Pros and Cons of Cross-Drilled and Slotted Rotors - Autos.com
Slotted Rotors Vs. Drilled Rotors | eHow.com
Hers two opinions....and I call them opinions because that's what they are. Please do your research before you make such an important descision on track brakes. It can mean the difference between having a great/fun day at the track and wrecking your car or worse getting hurt.
My˘.02
**edit** almost forgot, as Betty has said change/flush your brake fluid and replace it with high temp fluid. If your fluid boils, an awesome set of track brakes won't matter. Amsoil makes high temp fluid. Also, might want to invest in a good set of tires...they aid in braking as well.
4DRZ
03-28-2017 01:54 PM
joebrez
09-22-2015 11:54 AM
