Worth dropping/lowering the S model on springs?
So just out of curiosity, is it worth dropping the Sport model? Someone told me that by getting springs, im downgrading the sport model as it already has great handling.
I love the way car handles. But with springs and the drop, am i downgrading or improving handling? I know i can pick up new springs for like 200-300 bucks.
13 g37s Sedan 6mt.
Thanks,
Roman
13 g37s Sedan 6mt.
Thanks,
Roman
Who told you lowering the car downgrades the car? Maybe depreciates the car's value, but no way does it downgrade the car. I don't think anyone of these forums have regretted lowering their car, even if they experience some battle wounds (ie rubbing, scraping, bottoming out, etc).
So in a nutshell, yes - do it. It'll improve both handling and looks of the car.
i loved the stance, handling and overall impression from a performance point of view when i was lowered on eibach prokit. i was running 20mm spacers front and rear. the setup looked great.
i did go back to stock springs after a few years only because i was tired of scraping and bottoming out, or having to drive like a paranoid OCD victim. whenever i had passengers i had to be extremely careful over speedbumps or on driveways. it got tiresome so i had to make the change back to stock. i do miss the handling and look of the prokit though!
i've found that by adding the eibach sway bars and a better set of tires i have regained any handling "loss" after removing the prokit. body roll is minimal, sharp turn-in and good stability through corners. all with not having to explain to passengers "don't worry, that sound was just the cross-brace scraping".
just my 0.02.
just my 0.02.
Sorry guys what I meant was, I read or heard that sport model suspension is setup good as is, and that springs won't make much of a difference at all because of sport suspension on this car.
So even with sport suspension, its worth it?
I like the way you think. Infiniti spent millions developing the G37 sedan. Then the masses slap on new springs and who knows what else and claim they "improved" the car. No, you just screwed up the suspension geometry and handling that Infiniti developed. Can factory suspension be improved? Perhaps. But the odds of doing so simply by lowering the car to get the perfect "stance" aren't very good.
did you not read what i wrote?? what are you looking for?? handeling? get aftermarket sways. lower your car/get rid of wheel gap then get springs, if you have more $$$ opt for coil overs. why would anyone swap out OEM equipment for aftermarket if there wasn't some kind of improvement? If you never owned a sports car or sports coupe then the suspension would be good. if you drive aggressively and continually hit the limitations of your current set up, or dont like the way the car rolls or dips in corners then you do suspension upgrades like sway bars and coil overs. if you dont like the 4x4 wheel gap that newer cars come with these days then you get springs and spacers. All aftermarket springs for our cars offer some degree of drop. seriously use the search function.
It's amazing what that slight bit of height made though, no more paranoia
Sport pkg has pretty decent sways, so should get you decent handling improvement w/ some compliant springs, but definitely go Coils if you can swing it.
Thanks for all the replys.
I'm not an idiot, I know the results of getting springs would be lowered car with stiffer handling.
My question was specifically about sport suspension model and adding springs to that.
I am perfectly happy with the handling, for now anyway, I was only curious about sport model suspension.
Those with sport suspension who got aftermarket springs, how do you like it? Which ones did u get and HOW MUCH IMPROVEMENT HAVE YOU NOTICED?
thanks guys
thanks guys
Aside from the impracticality, I've always thought lowering a car looks rather childish once the top-of-wheel gap gets noticeably more narrow than the sides. It takes a serious amount of proper attention to lower a car properly, with the right rims, tires, offset and reasonable height. And even then, you have to deal with the impracticality of daily driving, like canucklhead here.
The Sport suspension on the RWD G37 is so much better than the non-Sport (or G37xS, for that matter), but you can improve things with aftermarket sways and coilovers. And the likelihood is that if you do go with coilovers, then you'll drop the car a little, because you can.
Yesterday I parked my stock-suspension 6MT nose-2-nose next to a G25x, at the end of a parking lot. It gave me the chance to step back and compare. The differences between the two were so obvious, I was kind of amused.
