G37X AWD Coupe brake pad issue
Old 06-22-2013 | 11:57 AM
KNS Brakes's Avatar
KNS Brakes
Originally Posted by nbast
Not sure if this helps, but I put Akebono ceramic pads on my 2009 X coupe.
parts numbers:
ACT888 - Front
ACT905 - Rear
Yes
The 888 and 905 are the universal 'D number' for the pad.
Most pad makers will use this numbering scheme.
However - the system isn't perfect due to the manufacturer's. There are pads so close w/ different D numbers that you might only make one of them. (Example a chamfer angle or some other very minor difference)
Centric makes 2-3 versions of the 905 pad for example and Hawk uses the other D1288 for your car. The diagrams show almost no difference between 905 and 1288
Basically it's easy till it's not easy - then it gets all screwed up.
Old 06-24-2013 | 03:57 PM
ai3j50's Avatar
ai3j50
Originally Posted by KNS Brakes
If you tell me what kind of car you have,year, sedan/coupe, rwd/awd. I can get you the correct parts.
-Nick
I have a 2010 x coupe. Just need to know what size rotors I need
Old 06-24-2013 | 04:22 PM
KNS Brakes's Avatar
KNS Brakes
The rotor size you have should be 330x32mm
I have these in stock in a Centric Premium front and rear.
KNS Brakes
-Nick
Troop12
05-09-2018 02:40 PM
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
zero260
08-12-2015 10:02 AM
Peter Reynolds
08-06-2015 07:53 PM
Quick Reply: G37X AWD Coupe brake pad issue
