Coils to bags questions
UAS has great customer service and are great at getting ahold of them... I would say it would be best to call and speak with them directly... There are definitely better coil shocks to run with bags than others... to be honest, if you are getting bags and know it... you should just wait and get Koni shocks to match them with...
I run KW V3 shocks as those are the coils I had and they are not the best as far as range with bags and they were not as easy on the install due to the top mounts, but it is a great ride! So some of it will depend on what you really want out of your setup.
My biggest thing is when I'm parked I want to air out all the way. I have seen bagged cars and were on these assembled purchased kits and looked as if the front or the rear was not down all the way and had no adjustments or need special brackets or other welding. My thought process is if I do a bag over coilover setup I can simply drop the bag to the height I need it as if a static setup and achieve my fully aired out look and raise it when needed with the bags. So far I got Stance GR+ Coilovers, Dakota Digital 5 way display, 5 Gal 7 port Aluminum tank, Dual Viair 444c Compressors, awaiting on 1 set of UAS Aerosports bags. I need to get Accuair VU4 manifold (version 2), Accuair speed controller, 5 sending units, and one more set of UAS Aerosports. Everything else the installer is supplying in with the install price. Looking to have this wrapped up by next month or the next.
