S-Tech Tein Springs on G37x (AWD) ?
So this guy I know has a '12 G37xS sedan dropped on S-tech springs which are for the RWD. He said he has had no issues with it whatsoever. The drop looks much better than springs made specifically for the AWD like Eibach, which tends to have the rear sit lower than the front. So I was just wondering, would this setup be safe to run with spacers?
Reference, his car:
Reference, his car:
![](https://sphotos-b.xx.fbcdn.net/hphotos-snc6/191981_355106911253442_981611987_o.jpg)
Also, are you it looks better than the Eibachs? Because to me it defiantly looks like the rear is sagging quite a bit verses the front.
S techs are a pretty deep drop for the AWD, especially if you're dealing w/ snow on a regular basis. Swift seems to be the perfect recipe for the X models, plus you'll need a full camber/toe kit w/ S techs, should be able to keep your stock camber/toe pieces w/ the Swifts (save you about $500 + the labor.)
i have swift springs on my g37x sedan and i had to get a camber kit to get the alignment within specs. the front on all awd sedans sags compared to the front. My car is the same right now, the front has a 2.2 negative camber and the rear is completely fine. i'm ordering tein s springs to replace the rear springs to level the drop hopefully it helps.
I've had a '12 G25X for 9 months and lowered it on Eibach's - bad mistake the back definitely sags more than the front - looks turrible. I'm switching to Swift's...lesson learned.
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
MeatySock
08-14-2015 08:25 AM
