G37xS lowered on Swift Springs
Old 11-13-2012, 05:50 PM
awais
awais's Avatar
Lowered my car last week. It's a MY 2009, which do tend sit lower than MY 2010+ sedans.
I do not have any before pictures of the stock height. I am sure everyone has seen one.
Here are the after pictures. I have stock coupe rims, all four are the 9" rears with 245/40/19 tires.
Uploaded with ImageShack.us
I can say that the ride is definitely stiffer, but there is absolutely no roll when turning. I will update as I do more miles.
Old 11-13-2012, 05:56 PM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
Looks good! Was it an even drop all around? Just out of curiosity are you going to black out your chrome trim on the doors?
Old 11-13-2012, 11:20 PM
Received 4,943 Likes on 4,176 Posts
Looking nice, liking those painted 19s on there Haven't heard the 2010+ sit higher, all the suspension components are the same from all I've read. I know the 2009+ are heavier than the 2007-2008s equipped w/ the AT though.
If you want to black out your window chrome and paint your tails here's a couple of my DIYs if you want to go that route~
https://www.myg37.com/forums/d-i-y-i...-g-sedans.html
https://www.myg37.com/forums/d-i-y-i...ils-sedan.html
Old 11-14-2012, 01:44 AM
JJsBusaRox
JJsBusaRox's Avatar
Looks good. It could go another 1" in my opinion.
Old 11-14-2012, 08:00 PM
awais
awais's Avatar
The drop looks even front and back. I will add measurements soon. I will be definitely blacking out the chrome trim on the doors.
Thanks for the DIYs, I will definitely black out the chrome trim. When I read through the swift springs thread for awd here the 09 seemed lowered a bit more.
I am happy with the drop. It could use some 10-15mm spacers for a flusher look.
Old 11-14-2012, 09:53 PM
sneakers
sneakers's Avatar
I also have a G37xs 09. Hows the ride quality, cornering, acceleration and handling on the 19s before the swift compared to stock? I am debating on getting new wheels and if I do, whether its 18s or 19s (currently on 18s).
You mention you're on 19x9 and want to add spacers. You think I can get away with 9.5 or mabe even 10", all around setup without rubbing when I lower it too? Thanks.
Old 11-15-2012, 11:41 PM
awais
awais's Avatar
I am not an expert of wheels, I believe you will have to take the wheel offset into account along with the width of the rim. I am posting this from my phone, there's a good wheel offset calculator I think on tirerack that uses your current setup to calculate different setups.
Old 11-16-2012, 12:25 AM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
If I may ask, where did you purchase your springs from?
Old 11-16-2012, 01:18 AM
Dad
Dad's Avatar
Nice looking set-up. I love the drop! Sporty but not bump-a-dump. I have a 2010 G37S and have been thinkin' hard about the Swift Springs. I like the idea of linear loading but haven't been able to contact anyone in a technical capacity to get some feedback. I connected through their website and they just referred me to a local merchant who wasn't able to get down and dirty with some tech talk. The stock "S" suspensions ride a little stiff, but the dampening is pleasant enough. When you say it rides stiffer, is it more harsh than stock? Does it stick it to you up the spine (so to speak)? I would like to improve the minimal roll it has now and improve the rebounding but don't want to ruin long rides. What say you???
Old 11-16-2012, 10:26 AM
accohn12
accohn12's Avatar
did you get an alignment yet? Curious if you're out of spec. Love the setup you have w/ the S Coupe wheels and slight drop...not really a huge fan of the "blacked out" look, but to each his own.
Old 11-16-2012, 10:43 PM
awais
awais's Avatar
I picked them up from a local member near me. If you are around Toronto, TougeTuning sells them.
Perhaps you should look into upgrading the swaybars first if you haven't already done so. They will decrease the roll while cornering.
With upgrading swaybar the ride will only suffer minimal while improving handling and reducing roll. With the springs it's more fun to drive, however, the ride does suffer more. My car is a G37x, which has a softer suspension to begin with compared to a G37S. With that said, I notice I do feel more road imperfections. It doesn't send a jolt up the spine, but I am avoiding potholes and manholes more than before.
These springs are slightly used so I got an alignment right away after the install. I got both front and rear camber kits, so everything is back to specs. I decided I would rather spend 600 bucks than to chew through tires.
Old 11-17-2012, 10:20 AM
jepva
jepva's Avatar
Drop looks good to me, it's only going to sit lower over time so I wouldn't say it's not low enough quite yet.
Old 11-18-2012, 12:55 AM
awais
awais's Avatar
Washed the car
Got a chance to wash the car today.
DRLs
Old 11-18-2012, 10:30 AM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
Looks great! Didn't think I would like the completely blacked out look but I have come around and I love it.
Old 11-21-2012, 12:44 AM
Dad
Dad's Avatar
Thanks! Appreciate the input...
Quick Reply: G37xS lowered on Swift Springs
