Hotchkis sways vs G37S rear only
I'm trying to determine if the extra cost to add the Hotchkis sway bars is worth it over just installing the G37s coupe rear bar alone. Basically, it's a $400 vs. $175 question.
Thoughts?
Thoughts?
So if you've got a non-Sport Package G37, and are weighing the upgrade choice between OEM Sport sways vs. aftermarket sways... get the aftermarket parts.
Also, you'll likely be wanting to upgrade BOTH sways, not just one. Balance.
Thanks for the responses. I need to specify a bit. I have a g37x. My understanding is that the x and xs sways are the same on the sedan. Thus my interest in adding the g37s coupe rear only.
Any other feedback appreciated.
I have a 10' X sedan, and I swapped the rear sway bar from a S Coupe. I notice a difference in the way it drives, but the difference is minimal - not really worth it imo. If I could go back i would get the hotchkis. I read on this forum that the people who put it on see a huge improvement.
If you're gonna mess with it, do it right.
i did this when i was installing mine. i wish i had taken a picture.
the difference in size was laughable.
seriously.......aftermarket sways is the best mod ever!
install is a 30 min DIY. can't get much simpler. 2 endlink nuts and 4 bracket nuts. a very worthwhile and economical performance modification that you will actually notice.
m1cha3l
Buying & Leasing
41
03-09-2019 12:56 PM
