Hotchkis sways - which setting for the front?
Old 10-14-2012 | 11:32 PM
RonMJ's Avatar
RonMJ
My Hotchkis sways and Whiteline rear endlinks are here. I have a 2009 G37X. The front sway bar has two holes. Which one do people use and why? I'm going with the middle on the rear. Thanks
Old 10-15-2012 | 07:34 AM
ashmostro's Avatar
ashmostro
The settings adjust the stiffness of each bar. Closer to the bar ends means less stiff on that axle.
If you want to reduce understeer, you stiffen the rear and/or soften the front
If you want to reduce oversteer, you stiffen the front and/or soften the rear
The combination of front and rear settings is really what matters, so I think your starting point makes sense. If you feel the car is still understeering too much, go to the stiffer setting on the rear. If instead it's too oversteery, try the stiffer front setting.
Old 10-15-2012 | 05:10 PM
shivers's Avatar
shivers
Is this an X bar thing? My front bar is not adjustable.
Troop12
05-09-2018 02:40 PM
Team_STILLEN
Future Models
13
09-05-2016 03:13 PM
Mattlorentzoe
08-21-2015 03:54 PM
meme405
08-19-2015 07:45 PM
xpcgamer
08-10-2015 03:43 PM
Quick Reply: Hotchkis sways - which setting for the front?
