Toe Settings with Negative Camber 2010 G37S Sedan
I just got back from the alignment shop today to have my front and rear toe set after lowering my car. The specs are as follows:
<script src="http://img401.imageshack.us/shareable/?i=img04571g.jpg&p=tl" type="text/javascript"></script><noscript></noscript>
I have my stock wheels on right now because I'm waiting for a new set of wheels to come in. I need the negative camber so that is no worries. From my understanding I would want all 4 wheels to have a 0.00 (or as close as possible) toe to stop the tires from wearing prematurely. The guy at the tire shop was saying that the "toe in" on the rear was good because it makes the tires wear more on the outside and because I have negative camber this would be better than setting the toe at 0.00 in the rear.
This is counter intuitive to what I know to be the best way to set up the car. Can anyone confirm if I am right or the tire shop guy?
This is my daily driver and I don't care so much about the performance, I just want the tires to last a long time.
They might be able to do a better job on zeroing the toe. I dont know how much you lowered the car.
I a m lowered 1.5"front and 1.2" rear and the shop got mine to an acceptable value. No camber kits.
I have driven 14,000km since the alignment. I frequently check the tire wear with a gauge and everything is good and even.
Reading a number of sites on the net, Toe-In on the rear is desirable as it reduces tire wear due to the tendency of the tires to move to a toe out position when they start rolling and it also increases stability.
Whenever I look at any parked BMW the rear toe in is even more pronounced than on the G which is still very noticeable on a parked car.
So is there any documentation that shows why 0 toe is desirable (especially when there is toe-in from the factory?)
I have Eibach Pro Kit springs with Tokico Blue Shocks. I have currently only paid $45 for them to adjust the front end. They only charge if they have to do an adjustment.
Your rear tires will wear quickly as they are currently set.
maybeg37
09-08-2015 02:33 PM
