Drilled Slotted Rotors
Recently installed Power Stop drilled and slotted rotors on front of 2009 G37X.
While driving - coasting in particular, I notice a bit of a metallic rubbing sound coming from the front. Is this normal for those type of brakes?
The rear pads are low and I am considering NOT using the Power Stop kit there because of the noise/problem in the front.
Any advice/help??!!!
i have drilled/slotted rotors on my G and i do not have any rubbing or sound coming from anywhere while coasting.
i would check to make sure that the pads are installed correctly.
also, if the rear pads are low the rubbing sound may be coming from there.....possibly.
photocat
09-03-2015 01:46 PM
