BC BR Coils installed, clunking from rear passenger
Old 10-01-2012 | 09:41 PM
Dark Sarcasm's Avatar
Dark Sarcasm
Anyone have a fix for the clunking noise from the rear BC coil overs?
Old 10-03-2012 | 06:13 PM
GTLAW's Avatar
GTLAW
Yep get KW !
Old 10-03-2012 | 06:40 PM
timfactor's Avatar
timfactor
Tighten top nut on shock. If its tight call BC
timfactor's Avatar
timfactor
Did u install them yourself?
Old 10-03-2012 | 10:47 PM
Dark Sarcasm
Installed myself. I'll try the nut on top of the shock. It seems like it comes from the spring tho, if I grab the spring and push n pull on it there is a slight bit of movement.
Old 10-03-2012 | 11:16 PM
second2none's Avatar
second2none
I have bc coils and no clunking. You sure they are seated and bolted down properly?
Old 10-03-2012 | 11:54 PM
OB G's Avatar
OB G
If you can move the spring then you definitely don't have it preloaded correctly.
Old 10-03-2012 | 11:55 PM
G37Pillow's Avatar
G37Pillow
Samn here BC coils and no problems.
Old 10-05-2012 | 05:13 AM
revealer's Avatar
revealer
i have that same issue i only get it when going at low speeds and hit a dip or bump but very minimal above 20mph no more.
Old 10-05-2012 | 08:25 PM
Dark Sarcasm
i dont hear it after 30 mph.
Old 10-05-2012 | 08:28 PM
Dark Sarcasm
i didnt really understand the directions for preloading the spring.
Do you (anyone) know the proper way to preload?
If I remember right, I unbolt the shock and the lower arm and let everything hang loose, and then slowly jack up the lower arm until the rear spring is seated, and then jack it up 10mm more, set the lenght of the shock and then tighten down all the bolts. IS this correct?
Old 10-05-2012 | 08:32 PM
Schulminator's Avatar
Schulminator
That's the way I did it.
Old 10-05-2012 | 11:34 PM
timfactor's Avatar
timfactor
Correct.
Old 10-06-2012 | 12:18 AM
Dark Sarcasm
Okay, thanks fellow G's. I guess I will take that side apart and see if I messed up on the install somewhere. Thanks again
Old 10-06-2012 | 11:11 AM
timfactor's Avatar
timfactor
Let us know
superjoey
31
03-23-2023 12:56 AM
Thedbarz
33
02-09-2016 01:05 AM
Ricio1991
08-23-2015 11:44 AM
VIVID
08-03-2015 03:40 PM
