Can I put a spacer under top strut mount?
Old 09-24-2012, 08:59 AM
Received 4,942 Likes on 4,175 Posts
I had to add 15mm spacers to clear BBKs and now I'm concerned that my low drop will trash my inner fender liners or worse. I never had much issue before but since adding the spacers my tires have already rubbed the inner wells a couple times yesterday. My tires are about 1/2" under the fender lip, I think a 1/4"- 3/8" lift would be much better. Was wondering if I put a hard rubber spacer between the under fender well and the triangle top strut mount be OK? Surely don't want anything dangerous, but has anyone tried this. Don't really want to get new springs, coilovers are in the works but would like an interim fix in the mean time. Thanks for any help you can provide.
Old 09-24-2012, 09:12 AM
What are you lowered with? Presuming you are dropped with coilovers, wouldn't it be much easier to simply raise you ride height a little bit?
Old 09-24-2012, 02:24 PM
BB, it's a spring drop (pretty low at 25.6" to the fender), coilovers are on my wish list but not until I get the BBK. I guess I'll just take it easy in the mean time.
Old 10-14-2012, 07:21 PM
Track Bandit
Track Bandit's Avatar
Sure you could do that but I wouldn't use rubber since I doubt you could find some hard enough not to eventually compress out of shape in that area. Just try using some aluminum shim material cut in that shape and thickness. It shouldn't add any more noise to the setup or very little. JMO
Al
ladydriveng37
10-11-2015 05:23 AM
WillCo1
08-25-2015 02:25 PM
Roadrash666
08-25-2015 01:03 AM
MJ HINX
08-23-2015 10:30 PM
Zach Stewart
08-18-2015 05:01 PM
Quick Reply: Can I put a spacer under top strut mount?
