Sway bar question
Sway bar question
hey, so i just purchased myslef a 2009 g37xs, i know that the sport adds the stiffer suspension, so the question i have is would it still be worth it to add a sway bar, all responses are appreciated, thanks
It is still worth it IMO. If you reach out to Hotchkis specifically, they'll give you the rates of how much more stiff their bars are than stock. It's all up to you though.
I have an S.
Said this before...
Aftermarket sways, whether hotchkis, whiteline, or eibach, is the BEST mod for noticible results vs money spent.
You will not do a mod that is as inexpensive as sways that you will feel more.
Said this before...
S package on X only adds the appearance mods. The suspension is the normal non-S suspension. If you want to stiffen up the ride and improve the handling dramatically, get beefier sway bars.
Agreed. Whiteline will GENERALLY be the pricier option of the bunch but not by much. Quality and performance wise, that's really a subjective question. I personally have whitelines on my car (never tried hotchkis or eibach sways/anti-rollkits)- only because it was recommended by a widely respected local autoshop. If you're also willing to add a front strut bar from GT Spec or Cusco, you'll get even better results. All for under $700. Sway bars from any of these respected brands will make a dramatic difference to the car's turn-in handling, especially with the G37x. I will caution that the ride quality will also become significantly bumpier.
https://www.myg37.com/forums/3016244-post1.html
Eibach
FRONT:
OE bar: 26.5 mm (1.04 in) tubular
OE measured bar rate: 63 N/mm (362 lbs/in)
OE bar weight: 3.06 kg (6.7 lbs)
Eibach bar: 32mm (1.25 in) tubular and
adjustable
Eibach measured bar rate: 2 position adjustable
P1 = 128 N/mm (730 lbs/in)
P2 = 158 N/mm (900 lbs/in)
Eibach bar weight: 5.8 kg (12.8 lbs)
Bushing: New urethane bushings
End Link: OE
Approximate installation time: 1.0 hr
REAR:
OE bar: 24.3 mm (0.96 in) tubular
OE measured bar rate: 69 N/mm (394 lbs/in)
OE bar weight: 2.04 kg (4.5 lbs)
Eibach bar: 29mm (1.1 in) tubular and
adjustable
Eibach measured bar rate: 3 position
adjustable
P1 = 110 N/mm (627 lbs/in)
P2 = 130 N/mm (741 lbs/in)
P3 = 151 N/mm (860 lbs/in)
Eibach bar weight: 4.9 kg (10.8 lbs)
Bushings: New urethane bushings with grease grooves
End Link: OE
Approximate installation time: 1.5 hr
http://performance-suspension.eibach...g35g37_ark.pdf
