Help How many times can OEM rotors be turned?
I've had my OEM Akebono sports rotors turned 2 times by the factory in an effort to stop the brakes from squealing. Well the rear brakes are squealing again and it's almost time to replace the pads.
Is there a general rule for how many times rotors can be turned before one should purchase new ones? I understand that it depends on how much was actually removed each time, but I don't want to remove the rotors and take them to get turned only to find out that it's too thin and I'd be stuck without new rotors to install. Thanks!
they really shouldn't be...
it's a wear item and like anything else we've figured out a way to prolong their life.
ultimately, as mentioned above, you are just thinning out the rotor face and inevitably weakening the rotor's integrity.
let us know when swapping brake time is here and we'll get you squared away with some great customizable brake rotors to your liking w/pads and/or line packages also available!
One: turning a rotor has no effect on the noise that comes out of the caliper. The noise you are hearing is a vibration of the pad when the pad comes into contact with the rotor. If you have a high torque pad and you gently apply the brakes the pad will make more noise, if you apply the brakes hard there generally won't be any noise.
Two: If you need pads and rotors we have lots in stock to help your needs, we have pads ranging from street to full blown race pads. We have your average everyday white box rotor to your full blown treated 2-piece rotors.
When it comes time to replace those items, give us a call and you will get much more than just a price quote.
-Nick
Usually it's 1 mm per side so if it starts at say 24mm it can go down to 22mm.
PS
Your adviser owes you a set of rotors. Turning rotors to reduce noise is exactly the opposite of what I would suggest. Fresh iron squeals more than a rotor w/ a proper transfer layer.
Rebed the pads.
-Ken
Selling products is why they are here. If they're not going about it in a shady or dishonest way (we've had our share of those in the past) I'm fine with a little promotion of their services or products.
