Hello - I've read on this forum how many people experience sqeaky brakes due to it being cold in the morning as well as the size of the rotor. Apparently this is a design issue with the G37. Aside from sqeaking, how do you know when its time to actually change the pads or resurface the rotors? Is there a warning light or a recommended mileage when this service should be performed?
Anytime you rotate the tires, you should look inside to see how much pad you have left. I think most people get between 15-30K miles, depending on type of driving.
