It better ride good! The 19's make the ride worse, as compared to the 17's that were stock, but it's not too bad, just worse than the 17's were. Likely the tires since they are low profile.
1. you should be able to find labor for around 300, depending on the area though
2. if you think the ride is a lot worse with the 19's - then you will NOT like the ride with ANY lowering spring as they make the car stiffer.
I couldnt stand the floaty ride with the 17's and thought it was perfect with the 19's. Then i lowered it, and i usually dont mind lowered cars so to me its ok, but sometimes the bumps are painful. Now im on 20's and for some reason i like the ride better than 19's... dont know why.
I can handle a stiff ride. i was just saying the ride is much more sporty than the cool floating feel of the stiock sedan on 17's.
I had my 20's installed a few weeks before installing Eibach springs.
From my perspective the Eibach Prokit didn't make the ride feel any rougher, in a straight line, than the stock springs.
Switching to 20's had far more impact on the feel.
