Upgraded Endlinks for Sway Bars?
I've read that some people here have changed the OEM endlinks and put on upgraded/ heavy duty endlinks with their sway bars.
Does it really make a difference? What are some of the pros and cons of doing this?
I am putting on my hotchkis sway bars this weekend and not sure if I should purchase new endlinks.
Thanks!
Thanks!
it it has alot of other properties that make them a good upgrade to go with aftermarket swaybars. A major one is to get rid of the preload. once you put on aftermarket sways you'll notice that the oem endlinks will already be turned in a certain direction, this bias inhibits it's full range of motion and will not allow you to fully utilize your swaybars. the adjustability allows for the installer to correct that; you can sit in the car to have them factor out your weight too. assuming you care about the handling (reason why you purchased the sway bars in the first place) endlinks deserve the same recognition.
also, i had no idea they changed the oem endlinks at all... if that's true i guess you dont have worry about them breaking but they are, for sure, not adjustable. i dont see why infiniti/nissan would make any changes as all considering, there have not been any endlink failures when pair with oem swaysat least to my knowledge). there have been endlink failures with aftermarket sways though.
The end links in the 05-06 G35 are the same as the end links in the G37. Earlier years had an older type end link that has been revised. Either way, there has been many failures of end links in both G37s and G35s.
The advantage of adjustable end links are beyond failure prevention just like jujubii said. This is especially important when you have aftermarket sways and lowered suspension height.
delfinparis
11-16-2015 02:26 PM
dedmanchan
09-24-2015 11:25 PM
