Swift Springs RWD Sedan
#46
From Swifts website:
- The most consistent spring rate throughout the stroke
- The largest amount of stroke
- The highest durability against loss of spring height
- The lightest in weight
I surely will be going with Swifts when I do my conservative drop.
Choman (02-26-2014)
#47
The alignment went great. No camber kit needed because it was within spec.
Thanks Brother.
#48
This is true due to the type of spring they are. They are Linear vs. a progressive type spring. Linear as the name implies means they are not forgiving like a progressive spring.
Choman (02-26-2014)
#49
Great input rm. the most consistent spring rate throughout the stroke and the largest stroke are so important. In other words, the Swifts don't bottom out (max compression) like progressive springs. It's such a smooth ride with great handling. Just look up pictures of them and you will see a design difference.
we should probably highlight the fact that the RWD and AWD drops are slightly different for those AWD lurkers like myself who are interested.
#50
Yes, that is true. Swift springs are linear versus progressive and don't need to settle. Remember though, there are rubber bushings that will compress so I'd wait at least a week before an alignment but you really don't need the waiting period.
Lowering my G was pretty much my first mod. So when I started looking into lowering, springs were the financial option for me. I called Swift, they didn't have RWD sedan springs and they asked if would help them create the springs. I helped them and after using these spring I believe in them 100%. It was the mild drop I was looking for plus I didn't want to compromise my ride quality.
Thanks Brother.
Thanks Brother.
How are your struts holding up since the installation? That is the only downside to me, replacing the OEM struts when the time comes. There deosn't appear to be exclusive aftermarket struts designed for the sedan RWD.
Bota36 (02-27-2014)
#51
On my last car (2003 Maxima SE 6MT), I had installed a rear sway bar bar where there wasn't one before... replaced the struts with Tokico Blues, added a front strut tower brace, and a rear-strut tower brace, installed Energy Suspension bushings everywhere, including the engine mounts, and at year seven of ownership had replaced/upgraded front wheel bearings, ball-joints, tie-rod end links, and sway bar end-links. The car was tight as a drum, and on top of all that I was running with these amazing Goodyear Eagle F1 performance tires.
Then I got in a buddy's 2001 Maxima AE, who was riding on all-season tires, with heavy 19" rims. He had all original suspension parts, with over 100K miles and a decade of Canadian winters, without any suspension upgrades what-so-ever... except for a used set of Tein SS Coilovers. And the bastard could run circles around my car.
The lesson learned here: coilovers FTW.
Choman (02-26-2014)
#52
Bota - your current setup looks great! I am drooling over here! Thanks for the input as well.
I know members have talked about the Swift Koni combo but I'm not sure if it applies to the sedan. I'll have to look into it.
#53
This thread has convinced me to get some Swift springs so thank you Bota!
I'm on Koni Yellows for struts but on the stock springs. The stock struts were getting sloppy. The odd thing about going to the Koni's is that the front sits about an inch higher than it did pre-Koni's. I'm not sure why but I'm definitely going to pull the trigger on the Swifts to correct that.
Glad to also hear that no camber kit was needed!
#55
There is the Swift/KYB combo that Soundmike had~
Brief review of Swift Mach springs - G35Driver
#56
Thanks for the link Brad.
Looks like they have sedan verisons for the KYB GR2s. Are these the only guys who make direct replacmeents for sedan struts/shocks? I know people have tried the Koni Yellow's but those were designed specifically for the coupe.
#58
Interested to see pics and get your feedback on swifts + koni shocks.
#59
There's also the Koni H&R combo, and from the notated drop it should be a good alternative to coils, but AFAIK it's only available in Europe
Infiniti G Series G37 Coupe Koni Sport Suspension Kit 1140-9589 Only £760.32
Koni Infiniti G-series G37 Coupe 08-12 Sport Suspension Kit - Motamec.com
Koni Sport Suspension Kit (with H&R Springs) for Infiniti - larkspeed.com
#60
Bota,
From the research that I've done, there aren't many others or any at all who make a direct OEM replacement for shocks/struts on the sedans.
That is making me move more towards coilovers, especially based on what Rochester posted earlier.
