Help - Torque Spec for G37x Strut Pinch Bolt
I am installing Swift springs on my 2009 G37x sedan and need the torque specs for the bottom pinch bolt on the strut. I did a search but can't come up with that one spec. Any help would be appreciated.
BTW, pretty simple DIY....no impact wrench needed.
RJ
RJ
I found one torque spec for a G35 that says the bolt is supposed to be torqued to 83ft lbs, but idk if it's the same set-up for the G37.
Call any dealership service dept, and they should be able to tell you for sure..
RJ
lobuzz311
16
10-17-2016 08:59 PM
2012, bolts, fast, front, g37, g37x, infinitig37, intentions, lower, rating, specs, strut, struts, suspension, torque
