front camber bushings
my spc front camber bushing is worn out, it start to making "bushing" noise when I hit any bump. would it cause any safety issue if I don't replace them?
Thanks!
Thanks!
can you please explain "bushing" sound?
I have a "rattle" that comes from my passenger SPC upper control arm.. when i jacked up the car, i saw that it was extremely loose. I tightened it, which took care of it for a few weeks.. now it's back. I shouldn't have to keep tightening it every few weeks or so. if it's the same problem that you're having, i guess i'll also be contacting SPC...
I have a question for the OP.
How many miles are on those SPC front camber arms of yours?
Do you drive on a lot of bumpy & twisty roads?
Sorry, I guess that is two questions. Thanks
i tightened them but you can still hear some of the noise in certain situations. its only a matter of time before it gets worse.
i have probably 30-35k miles on my arms, well on the arm im referring to, the other had to be replaced because it bent to all hell and back
Guys i recenly had contacted Brad at SPC because my front SPC arm failed on driver side. Ball joint was bad and i sent back to get a new one sent to me even though i purchased 2 years ago. Contact whoever you purchased from and have sent out for replacement. Lifetime warranty on SPC products!
Majeed Bader
10-08-2015 10:52 AM
