Tein Coilover damping adjustment questions.
Old 05-03-2012, 12:13 PM
Redvoodoo
Redvoodoo's Avatar
I have Tein Coil-overs and have never adjusted the damping. I want to make the damping stiffer to try and keep my tires from rubbing my fenders on big dips.
How do I access the rear adjustment ****? Do the wheels need to be off? Do I need a special tool to adjust the *** or can it be done by hand?
Which direction, clockwise or counter-clockwise to stiffen?
What is the percentage of stiffness added per click on the adjustment ***?
Thanks!
Old 05-03-2012, 12:27 PM
WPPJR30
WPPJR30's Avatar
Don't let Betty see this thread... Don't be ignorant all of your life. Please...
Old 05-03-2012, 12:38 PM
Redvoodoo
Redvoodoo's Avatar
Better? Ha ha!
Old 05-03-2012, 01:04 PM
Weiboy718
Weiboy718's Avatar
There should be a adjustment **** on the upper side of the shock body. You would need to jack up the car in order to reach it however you should use a jack stand just to be safe.
Have you trimmed your fender liner and bumper bracket yet?
Old 05-03-2012, 01:18 PM
frty9rsfn
frty9rsfn's Avatar
---> at the above comments....
there should be an adjustment **** like weiboy said... turn it clockwise to stiffen... the stiffness per click depends on which coils you have actually... you got the Flex or SSP...?
i can feel the difference changing by 1 click... specially at 2 clicks... others might think different... im a suspension guy, so i can feel the slight change...
Old 05-03-2012, 02:05 PM
Redvoodoo
Redvoodoo's Avatar
I have not trimmed the fender liner or bumper bracket. I was hoping I would not have to do that. I will have the car up on a lift on Saturday to replace the tires, so I was planning to make the adjustment's then.
Old 05-03-2012, 02:07 PM
Redvoodoo
Redvoodoo's Avatar
I have not been under the car since I bought it to see if the coilovers are the Flex or SSP's. I will try 2 clicks since I feel the suspension is pretty soft compared to my last car.
Old 05-03-2012, 02:13 PM
Weiboy718
Weiboy718's Avatar
What is your wheel specs?
Old 05-03-2012, 02:30 PM
Redvoodoo
Redvoodoo's Avatar
I hope to find out Saturday when I have them off the car for the first time since buying the car. All I know is they are 20" in diameter and they are Axis Angle wheels. I suspect the rear wheels are 20"x10".
Old 05-03-2012, 04:40 PM
Rad_Slinger
Rad_Slinger's Avatar
haha...betty is gonna blow a gasket when he sees this
Old 05-03-2012, 05:04 PM
Nope. I've done my part. I can bring the information to the masses, I can't make them read it. At least OP corrected himself except for the title that he can't edit. So maybe it's a win and he'll know better from now on.
And I see everything. Everything.
Old 05-03-2012, 05:21 PM
Redvoodoo
Redvoodoo's Avatar
Sorry for the mistake. I too have my annoyances. Such as people that use the non-word "Irregardless". That one really gets under my skin.
Old 05-03-2012, 05:43 PM
I like the way you think.
Old 05-04-2012, 12:07 PM
Redvoodoo
Redvoodoo's Avatar
So if they are the Flex, will one click clockwise be more or less stiff than if my coilovers are SSP's?
Old 05-04-2012, 05:26 PM
frty9rsfn
frty9rsfn's Avatar
The Tein Flex Coils are stiffer... so more stiffer to answer your question...
Quick Reply: Tein Coilover damping adjustment questions.
