weird brake sound
weird brake sound
Hi guys
i have a g37s with the bbk and when the brake are hot under normal driving condition, you can hear a clicking sounds coming from the brake when i press the pedal. at first i thought it was the ypipe that were hot et that was making that sound but i brought the vehicle in at the dealership 3weeks ago and they cleaned the brake but the sound came back. Is it normal with the oem brake to make that kind of sound?
![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
Any problem with your brakes should probably be checked out ASAP by a professional (For the second time in your case). That's the one part you probably wouldn't want failing on you
The only sound I hear from my brakes is the stupid high pitched squealing in reverse, other than that, nothing. I have an 08 Sport.
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
