Southern CA Shops w/ G37 Tein Coilovers experience
Can anyone recommend a Southern CA shop with a lot of experience with Tein coilovers?
I bought a 2008 G37S coupe not to long ago, that has Tein coilovers but the dealer I bought the car from did not have the key or height adjustment tool to adjust the dampening and height.
Currently I get rubbing on the rear fenders when I hit a big dip at higher speeds or if I take a turn at high speeds with passengers (weight) in the car.
I am thinking that if I change to better/stiffer sway bars, currently have Stillen's, and make the suspension stiffer and/or raise the ride height a bit, I can solve this problem.
I am looking for a shop that can do the following all in one stop, with quality work at a reasonable price:
Install front camber arms (currently sitting my garage)
Install new, better sway bars
Adjust Tein coil-over dampening and/or raise ride height
Mount & balance new rear tires - current setup has too much negative camber
4 Wheel alignment
4 Wheel alignment
Try giving Henry a call at Temple City Auto Repair. They are mod friendly and also have a hunter road force balancer / alignment machine. Very nice guys there. Prices are more than reasonable.
Corner 3 does not have an alignment or balance machine. They do great work too but are not cheap compared to other shops in OC.
sunshineskyler
11-13-2015 09:47 AM
