Lowering question
Lowering question
I would like to lower my car with eibach springs because I can't stand the fender gap, but my driveway is steep and Im worried I would scrape going out. The only time I scrape the tailpipe now is with two pax in the back seat. Do you guys think the eibach drop will cause the car to scrape all the time? Anyone who did drop now have problems with their driveway? Thanks
flap now & then but that's it. With Eibachs you should be fine.
Sorry, I don't know what a 'PAX' is but if you already have an occasional scraping problem, then dropping it 1.2" in the rear is going to be a problem - especially if you put two 'PAX' in the back.
I have the Eibach pro kit but I don't encounter steep grade changes on regular, daily basis. For daily driving the Eibach's are a good, low cost option for sure.
i had the eibach setup before. i loved the stance, the handling, and the ride. my only problem was scraping on speedbumps and driveway crests - especially w/passengers. it wasn't the driveway approach so much, but the crests where the sedan's longer wheelbase would "high-centre" and scrape a cross-member. it drove me nuts, and after a while i determined that, even if i loved the look etc, i couldn't justify the nuisance for a daily driver sedan in my area (lots of hills). the coupe is much better suited to a drop since it is shorter wheelbase if one lives in a hilly area.
just my 0.02. i know others can put up with the hassle. i put the Z suspension my old '04 6MT sedan and that was an awesome setup at ~1" drop or a touch less.
Dropping your car will make you much more aware of anything that may get in its' way such as speed bumps or the dreaded speed humps (those elongated risers), road rubber, steep inclines, and snow over 3" deep. The ride and the look are soooo worth it IMO. I wouldn't want to go any lower though, only had a couple light scrapes on speed bumps and a couple bumper scrapes (just the underside, nothing noticeable), and now that I've been lowered for awhile I'm pretty good at navigating trough those beasts without any incident. Eibachs are a mild drop so with just minor precautions you shouldn't have any problems and you'll get rid of the 4X4 look.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
Simran Mann
09-13-2015 01:51 AM
