Help Suspension Help pics inside
Old 03-08-2012 | 01:35 PM
axelamoe's Avatar
axelamoe
Whats up guys? I bought this car a while back and it had Eibach Springs on it. I Installed some KW V1 on the Vehicle. I have an audio box in the trunk. Am cambered really bad and I hate this look. This is the highest setting set on my KW as of right now, am wondering what can i do to at least have the wheels sitting flush or raise the back a bit more so i can push the wheels out. BTW I have an SPC camber kit and this is the highest he can go and i Dont know the offset of the wheels (they came on it ), here are some pics:
Any help would be appreciated.
Thanks
Moe
Old 03-08-2012 | 01:36 PM
Kidcane's Avatar
Kidcane
Florida G Club
You could run spacers to push the wheels out more.
Old 03-08-2012 | 03:57 PM
axelamoe's Avatar
axelamoe
Ok but i will rub really bad and i cant raise the car anymore unless i go stock, and i dont want to do that.
axelamoe's Avatar
axelamoe
Can i put like a spring spacer or a stiffer spring to raise the car because of the weight of the speakers?
Old 03-08-2012 | 04:03 PM
Kidcane's Avatar
Kidcane
Florida G Club
IDK looks like you are hella tucked and still have a way to go before you are rubbing.
Old 03-08-2012 | 04:12 PM
emyrl's Avatar
emyrl
^what kidcane said, put on spacers, you have a long ways to go before you should start worrying about rubbing
Old 03-08-2012 | 04:13 PM
Weiboy718's Avatar
Weiboy718
I would like to know what camber are you set at? I had a similar problem before when I had my KW V3 and that's because I was running too much - camber.
Old 03-15-2012 | 10:10 PM
frty9rsfn's Avatar
frty9rsfn
did you install the toe kit as well??? if you didnt, then you wont be able to get much in spec on your camber even if you have the camber kit installed... i hadnt installed the toe kit at first and the camber wasnt put in spec because the toe wouldve been affected... just wondering on this one...
Old 03-30-2012 | 03:20 AM
dimsler's Avatar
dimsler
You can easily shove a 15-20mm spacer in there, then work on your camber, negative camber looks great if you're spaced out.
Old 03-30-2012 | 03:53 AM
XtatiC's Avatar
XtatiC
Since you have an SPC camber kit, you should be able to get a good allignment and fix that camber issue. Also agree that spacers would help make it look a lot better.
tomro99
11-17-2015 02:08 AM
si_driver
09-13-2015 12:04 PM
Simran Mann
09-11-2015 04:42 PM
OldG37
09-06-2015 10:38 PM
Quick Reply: Help Suspension Help pics inside
