Brakes & Suspension Reviews on brakes & suspension for G vehicles.
KONI Sport Yellow Dampers instal with pics.
Old 03-07-2012, 07:11 PM
TVPostSound
TVPostSound's Avatar
Wow! What a difference!!
I'm still running Eibach springs, but had the Koni dampers installed at Lou's place (Amplified Motorsport). Yeah, I got lazy, but Lou has given me great deals, and his labor rates are more than reasonable!!
First thing I noticed was a more polite compression, still stiff, but it felt like a much smoother stroke.
Rebound is another story, gone is the jarring rebounding from bumps, the pitchyness on corners is all but gone. On a rough road high speed corner, the tail wont kick out as before, the damper is leaving a lot of weight on the tires, not a jerky rebound.
Ride comfort has greatly improved, especially on the truck lanes, where the highway has been washboarded. I dont feel like a Honda with cut springs anymore.
Lou's installer said it felt a little soft compared to the 370Z install he did, but my opinion, is that it still has a "luxury sports car" ride.
Besides the Z had Swift springs, which are a higher rate. The G has 75 Lbs more weight at each corner than the Z
Im going to give it a couple of weeks, maybe switch to Swifts, as Lou tells me the Swift rate are stiffer, but the ride doesnt suffer.
IMG_0162.jpg?t=1331164705
IMG_0165.jpg?t=1331164700
IMG_0163.jpg?t=1331164686
Eibachs with modified spring perch, Koni shocks, and Hotchkis sway bars!!!
IMG_0159.jpg?t=1330813085
Old 03-07-2012, 07:21 PM
GET_SOME
GET_SOME's Avatar
wow very nice. now if only the front was a little lower id be all over this set up
Old 03-07-2012, 07:23 PM
TVPostSound
I think the Swift springs are a tad lower.
This was a 1.2" drop both front and rear
Im Ok with this, as I still have some suspension travel left!
Old 03-07-2012, 11:03 PM
xzeus
xzeus's Avatar
looking amazing
Old 03-07-2012, 11:09 PM
scotty_g
scotty_g's Avatar
Nice I can only hope they make this for awd one day.
Old 03-07-2012, 11:48 PM
TVPostSound
Not sure what hey will do, the coupe shocks were developed for the Z. approved for the G Coupe after pestering them to test it!!
Old 03-08-2012, 01:58 AM
Lou@Amplified
Lou@Amplified's Avatar
Great review Pat
Old 03-08-2012, 07:45 AM
v.b
v.b's Avatar
nice! I always wanted to try a similar setup but the arguement of "spend a bit more and get coilovers" always won me over. maybe some day... haha
Old 03-08-2012, 07:51 AM
SwissCheeseHead
SwissCheeseHead's Avatar
I'm waiting to get these until my stock shocks die...hopefully soon lol. Thanks for the review. I've got my swift springs waiting for on order and I'm totally looking forward to this combo someday.
Old 03-08-2012, 08:00 PM
TVPostSound
If your getting Swifts, you might as well spend the money on dampers!!
Old 03-08-2012, 09:50 PM
mishmosh
mishmosh's Avatar
How much damping did you adjust for to start out with? I don't think you will need much. with the Koni Sport inserts I've used in the past, a half turn was all it took.
Old 03-08-2012, 11:39 PM
TVPostSound
When I spoke with the Koni engineer, he left the test car at 1/2 turn out of 2.
As he felt that was enough for a "Sporty" ride.
I took mine to 1 full turn out of 2. Any more would be too much for my taste.
As a matter of fact, every Koni I've ever installed starting with the Reds in 1978, was half way!!
Thanks for asking, I forgot to mention it in the OP.
Old 03-08-2012, 11:48 PM
xtrafastcivic
xtrafastcivic's Avatar
You mentioned a modified spring perch. What do you mean?
Old 03-08-2012, 11:51 PM
TVPostSound
Dropping the extra 1/2" that Eibach doesnt provide!!
So I'm now lowered equally 1.25" both front and rear!
DIY: Cutting Rear Springmount aka "the springmount mod" - MY350Z.COM Forums
Does not affect anything but height.
VossenG37S
VossenG37S's Avatar
Clean drop! Defenetly better then stock. Great review for those w springs! Grab some konis lol.
Quick Reply: KONI Sport Yellow Dampers instal with pics.
