brake lights keep coming up after 6-7000 rpms
brake lights keep coming up after 6-7000 rpms.... and then it will go off i have a 2011 g37x coupe the only mod is an injen intake and i checked the brake fluid and it has a pretty good amount
I get the brake light momentarily until the RPM's go back down. I also get the Slip and VDC lights as well and they stay on until I turn the car off and then back on again. It's really starting to get annoying.
Add brake fluid. I thought I had plenty of fluid, with it being at the seam in the reservoir, but I added some fluid to the full line, and the VDC, SLIP and BRAKE lights all went away under acceleration. If you guys use the search function, you'll see quite a few threads on this issue, pretty common.
Yeah, I know that the brake fluid is Dot 3 but when I called Infiniti to inquire about the clutch fluid, they said that I'd just have to bring it in. Frankly, I'd prefer to just do it myself and save myself the green for having them just pour some fluid in some reservoirs.
Sadly, the closest Infiniti dealer is 2 hours away. There's a Nissan dealership in town, but they've flat out told me that they will not do any Infiniti warranty work. Oh well, I'll just take her to the Nissan dealer in the morning.
had the same issue with my other infiniti g37x and the problem was the brakes. They had to replace front break pads and change one sensor. Usually if the Vdc and slip or parking break cone on its either Brakes or brake fluid.
