Eibachs not low enough? but should be!
Old 02-18-2012, 09:09 PM
  #46
P Casey
P Casey's Avatar
Originally Posted by Domate
I personally believe the H&R springs to be more aggressive than the Eibachs. I'm on H&R with 25f/20r Ichiba spacers and feel it's a perfect fit with my stock 19" rims.
The drop is 'almost' too aggressive as I have concerns that 20" may introduce some rubbing which I currently haven't experienced thus far with my 19".
Rubbing will depend on what offsets you go with.
Old 02-19-2012, 12:37 AM
  #47
G37Sam
G37Sam's Avatar
Glad you had it fixed. I believe Eibach's offer the best stance before going with coilovers. The rear's on Eibach's could use a few more mm's drop but that would hurt us guys with the older FI Catbacks. I believe Tanabe springs in the rear would be even better!
Old 02-29-2012, 09:47 PM
  #48
TVPostSound
TVPostSound's Avatar
The perfect stance is Eibachs, with 1/2" cut from the rear upper spring perch!!
DIY: Cutting Rear Springmount aka "the springmount mod" - G35Driver
Old 03-03-2012, 03:45 PM
  #49
danny69
danny69's Avatar
here is a drop with eibach for the front..
BEFORE
AND AFTER
Old 03-03-2012, 05:19 PM
  #50
TVPostSound
Eibach with rear spring seat modification.
Old 03-05-2012, 07:38 AM
  #51
mtlg37
mtlg37's Avatar
Dannys drop is perfect. I might pull the trigger but not sure how it will look on the convertible since the beast is 450lb heavier ... hummm
Old 03-05-2012, 10:36 AM
  #52
danny69
danny69's Avatar
Its going to look even more sick. Dont forget spacers is a must!
04G35NYC
07-19-2016 01:42 AM
optikol
01-28-2016 07:31 PM
VIVID
09-29-2015 10:58 AM
VQCrew
09-26-2015 01:19 PM
Quick Reply: Eibachs not low enough? but should be!
