Brakes
Old 02-03-2012 | 03:55 AM
Gwiz2500's Avatar
Gwiz2500
Brakes
Just wondering if any of you have experienced issues with brake shudder on 08 S coupe's.
I had my rotors replaced under warranty as I believed they were warped as I experienced all the tell tale signs...
After they were replaced I still had play in the wheel when braking just as with the old rotors. When I took the car back to the dealership they said the rotors were perfectly round and couldn't find anything wrong and blamed it on my feathered tires. I eventually replaced my tires and the shudder is still there just as it was with the old tires.
Not really sure what to do as they claim not to find anything wrong...
Old 02-03-2012 | 05:45 AM
Aismail's Avatar
Aismail
Had the same thing, solved it by changing the pads not the rotors. Hope this helps
Old 02-03-2012 | 10:24 AM
OB G's Avatar
OB G
I thought the old TSB was to replace pads and rotors?
Old 02-03-2012 | 03:08 PM
Gwiz2500's Avatar
Gwiz2500
The dealer said my pads were ok though. Hmm guess its time to replace the pads then.
Old 04-11-2012 | 06:33 PM
Gwiz2500's Avatar
Gwiz2500
Got new pads, alignment and wheel balancing. Vibration is still there. Dealer said rotors are good.
Vibration is still there when braking....
What the heck is wrong?!?!?!?!?
Old 04-11-2012 | 07:06 PM
Polar_g37s's Avatar
Polar_g37s
Dont get garbage oem brake components.... from my experience with Nissan/Infiniti I have grown to learn that their brake pads and rotors are complete GARBAGE.
Old 04-11-2012 | 09:05 PM
Topher9425's Avatar
Topher9425
Have you conciserd your alignment??
Old 04-11-2012 | 11:04 PM
dtran2714's Avatar
dtran2714
The dealer replaced my front pads and rotors.
Old 04-11-2012 | 11:13 PM
btran104's Avatar
btran104
yea dealer replaced my pads and rotors too
Old 04-23-2012 | 03:40 AM
Gwiz2500's Avatar
Gwiz2500
To D_S_CUSTOMZ
Alignment was done when i got my tires balanced.
Old 04-23-2012 | 03:42 AM
Gwiz2500's Avatar
Gwiz2500
Just throwing it out there, is it possible for a tie rod to be bent or something else in the steering/suspension system to be broken?
Old 04-23-2012 | 10:34 AM
DashKid's Avatar
DashKid
I have had this problem many many times with my G and had this TSB twice by the dealer and still the squeaks came back, so I got sick of tired of going to the stealership and replaced my brakes and rotors. Now they are smooth as they can be, haven't had a problem since.
Old 04-23-2012 | 12:04 PM
soundmike's Avatar
soundmike
Nissan's are known to have very soft OEM compounds on their pads, which transfer and deposit an uneven amount to the rotors.
This is why most folks experience a vibration.
Old 04-23-2012 | 02:27 PM
Lucster's Avatar
Lucster
Can some one PLEASE Send me a paper with the work order for the change in rotor/break pads?
Old 04-23-2012 | 05:42 PM
DashKid's Avatar
DashKid
This all depends on what rotors you want. I got the EBC gold rotors, along with hawk pads.
The work order number would be all different.
Kojack
10-09-2015 06:53 PM
Mattimus
10-04-2015 02:33 PM
Bennyjoel
10-01-2015 12:56 AM
Soccer4555
09-30-2015 06:31 PM
VIVID
09-27-2015 10:45 AM
