Swift Springs 08+ X Sedan
Old 01-31-2012, 10:08 PM
  #61
Lee37xNJ
Lee37xNJ's Avatar
I think bat6wc has an 09 and his looks close to yours-mine seems to be about 3/8 lower in the rear.i checked the service manuals for 08 to2010 and the awd wheel well heights are very close.i'm thinking when the fronts go on they will be somewhere around 26 3/4-a little lower than i wanted to go.i think it is still only about 1in lower than a rwd sport so i guess it's not too bad-probably need a camber kit on the front at least.with the g35s springs on the rear alignment was in spec with some adj left so maybe no kit needed there.will keep you guys posted.
Old 01-31-2012, 10:57 PM
  #62
bat6wc
bat6wc's Avatar
08 MY here. If you can wait a couple more days, Ill have another alignment and my 19s back on for pics. Then I will be able to post before and after with the same wheel set up. Ill try and remember to take some measurements tomorrow
Old 02-01-2012, 11:25 AM
  #63
DustinEarnhardt
DustinEarnhardt's Avatar
Can't wait for the pics and numbers, bat. I'd been completely unaware of the Swift springs, but now I'm strongly considering them as a slightly more conservative alternative to the Eibachs.
Old 02-01-2012, 11:40 AM
  #64
D_Nyholm
D_Nyholm's Avatar
Still haven't heard back from Vinny ten racing, so does anyone know someplace on long island that is reputable to get these? I figure they were made the northeast so they would be available at more places. I'll have to send swift an email and see what they recommend.
Also, has anyone though about putting the spring isolators in to get .25" more height out of these? The way Eibach recommends?
Old 02-01-2012, 11:47 AM
  #65
mikejg
mikejg's Avatar
D_N, I ordered mine from FBParts (vendor here) for $320 shipped. Then just get them installed at a reputable shop. I went with local Nissan dealer b/c, believe it or not, they were cheaper than the normal shop I go to.
Old 02-01-2012, 02:13 PM
  #66
Lee37xNJ
Lee37xNJ's Avatar
FB Parts here also but i would think Lou at Amplified could get them.as far as isolators-i was looking to be at about 27in and i'm close enough as long as they dont settle too much-thought i read somewhere that swift winds the springs hot or some shat so they settle minimally? don't scrape going into driveway and the apron is pretty steep.will see what happens with the fronts and then when everything settles.if i get isolators i'll be back to where i was with the g35 springs and this drop looks good-i mean it's not slammed or anything.
Old 02-01-2012, 02:31 PM
  #67
mikejg
mikejg's Avatar
My measurements are after about 2 weeks (only 1 week driving as I was out of town). I don't think they'll settle much more, if at all.
I, personally, would not want to make it .25" higher b/c i think it's prefect where it is.
Old 02-01-2012, 02:49 PM
  #68
Lee37xNJ
Lee37xNJ's Avatar
Your drop looks good! just checked their website and under the FAQ section they state their springs are "preset" so there's no need to wait for them to settle before getting alignment-guess that means they will hardly settle.
Old 02-05-2012, 04:08 PM
  #69
mikejg
mikejg's Avatar
Anyone else get these put on? Post up some pics! The SPC camber kit is going on tomorrow.
Old 02-05-2012, 04:24 PM
  #70
Lee37xNJ
Lee37xNJ's Avatar
alright-got the fronts installed yesterday.heres where she sits-fronts dead even at 27in, LR 26 13/16, RR 26 15/16 with full tank of gas.dropped about a 1/2in from my current setup.LR was always a bit lower.fronts not as harsh as the 370z sport springs i had in.overall i thought they would be a little softer but still luvin the ride! threw in SPC front +rear camber kits today without the toe bolts. will decide if i'll put em in before i go for alignment in a couple weeks.did driveway alignment for camber with digital level after SPC install so i'm back to where i was after spring install-couple degrees neg.will keep everyone posted after alignment.
Old 02-05-2012, 07:17 PM
  #71
mikejg
mikejg's Avatar
So Lee, your's sounds like it's about 1/4" lower than mine. That's interesting. I wonder why. Oh well. I'm loving it either way
Old 02-06-2012, 12:58 AM
  #72
rsi-g37xs
rsi-g37xs's Avatar
I will post pics once I get mine installed. I kind of put it off since we just got over a foot of snow in Colorado so it might be a few weeks and they are saying we might get another storm at the end of next week too. hopefully its not bad though. I am itching to get these installed as the 4x4 look with 19" wheels looks a little funny.
Old 02-06-2012, 10:06 AM
  #73
Lee37xNJ
Lee37xNJ's Avatar
do you know if your suspension was loaded when everything was tightened-if not it will sit higher.you going to install the toe bolts with your camber kits? i'm still debating on installing mine.
Old 02-06-2012, 06:30 PM
  #74
bat6wc
bat6wc's Avatar
finally some decent pics.
BEFORE
AFTER
Old 02-07-2012, 02:56 AM
  #75
MistAminER112
MistAminER112's Avatar
Damn! Looks really good! Great low profile
Quick Reply: Swift Springs 08+ X Sedan
