Brake Piston Diameter on S Model (Sedan)
Anyone know the diameter of the brake piston on a S model (sedan) with 4 pistons? I'm wanting to try the Nu-Lok Piston Cushions from NAPA, and they don't have a direct cross reference, but I'm sure I could match one if I can find the diameter. Any help would be appreciated!
I'm assuming you looked here by now?: 2012 Infiniti G25 and G37 Sedan Specs and Options | Infiniti USA Official Site
In case you are 'click challenged' here you go: Aluminum 4-piston opposed front calipers with 14.0 x 1.3-inch ventilated discs/2-piston opposed rear calipers with 13.8 x 0.8-inch ventilated discs; 4-wheel, 4-channel ABS
Good Luck.
Good Luck.
Front brake
Cylinder bore diameter
41.3 (1.626) × 2 + 44.45 (1.750) × 2
Pad length × width × thickness
123.2 × 55.0 × 11.0 (4.85 × 2.165 × 0.433)
Rotor outer diameter × thickness
355 × 32.0 (13.98 × 1.260)
Rear brake
41.3 (1.626) × 2
95.8 × 41.5 × 9.5 (3.772 × 1.634 × 0.374)
350 × 20.0 (13.78 × 0.787)
Master cylinder Cylinder bore diameter
25.4 (1)
Control valve Valve type
Electric brake force distribution
Brake booster Diaphragm diameter
Primary: 230 (9)
Secondary: 205 (8)
Recommended brake fluid DOT 3
Rear brake
41.3 (1.626) × 2
25.4 (1)
Primary: 230 (9)
Secondary: 205 (8)
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
willstophe
14
09-14-2015 09:02 AM
