Toe Bolts?
Toe Bolts?
When adding camber arms to the rear, do you need to go with aftermarket toe bolts or can you use the stockers? I have ichiba camber arms, not installed, and I have been told that the toe bolts are not needed. Can anyone please shed some light on this?
What you should do during alignment is set the factory toe bolts to a neutral position first. That ensures even of the eccentric loosens, the alignment wont change.
SPL makes a square lockout washer to take place of the eccentric, that is the dogs bollocks.
I had really hopped that I would get some more responses on this. I cant believe that there is only 2 people with experience with this. To the two people that did respond, Thank you.
ck1109
10-15-2015 11:06 PM
