Aftermarket shocks and struts for the G Coupe.
Old 01-13-2012, 10:03 PM
apexi350z
apexi350z's Avatar
Tokico HP ("blues") are just like OEM. If they offer any performance advantage, it would only be minimal. Their Illumina line are more performance oriented. But not by a lot. They're damping is adjustable. Then they have the D-Spec which are performance struts and shocks.
Only Blues are available for the G.
ok, thanks for the info! I had the D-Spec on my previous 350z, and loved them! It has variable adjustment, and got rid of the bouncy ride instantly! Wish Tokico can make the same thing for our G, and I would get it in a heartbeat!
Old 01-13-2012, 10:11 PM
TVPostSound
TVPostSound's Avatar
Originally Posted by P Casey
Just trying to see if anyone has used or has these(Tokico Shocks). I would like to know if they improve suspension and to what degree. Also, what are some other aftermarket shocks and struts available for the G. I do not see many people using shocks and struts, I am going to get them this time around.
Thanks
UPDATE:
Koni has released their 370Z Sport shocks and struts.
Im waiting for an answer from my guy at Koni if they will exchange to a G37.
It might be possible, notice that KW3 coilovers use the same part for the Z and G.
Casey, want to be the first to try??
Swift Springs on Konis! just waiting.
For the coilover fanatics, I dont care if the cost for the above is more!!!
Old 01-13-2012, 10:12 PM
I've got Illumiinas and H&R springs on my old Maxima and I'm happy with them.
Old 01-13-2012, 10:13 PM
UPDATE:
They'll fit. Which Konis? Koni yellows and swift springs would probably make for a very good combo.
Old 01-13-2012, 10:27 PM
TVPostSound
Yellows!!!
Front
Left: 8241 1282LSport
Right: 8241 1282RSport
Rear
8241 1283Sport
Im seeing pre-orders for $940 for the set.
It looks like they are complete struts not inserts.
Ive already contacted Lou at Amplified!!!
Old 01-16-2012, 08:34 PM
TVPostSound
What led you to that conclusion? (Fit) Same as me?
That most coil overs use the same part # for G37s, as 370Zs??
I'm already the foglight guinea pig, someone take a stab at this!!
Old 01-16-2012, 11:08 PM
Yes those suspension parts interchange fit wise. Different spring or damping rates, but they physically will fit either. Of course you'll spend as much as you would for a set of coilovers and still not have height adjustibility, but if the springs drop it to the height you want I don't see any problem.
Old 02-22-2015, 11:51 AM
squarehead
squarehead's Avatar
Bumping this thread - have any aftermarket shock/strut options become available? Any well received/positive reviews?
Old 02-22-2015, 12:10 PM
Lego_Maniac
Lego_Maniac's Avatar
Koni
Old 02-22-2015, 12:31 PM
TVPostSound
Koni Yellows.
Tokico HP
TheIvoryG
09-23-2015 02:06 AM
JohnsG37x
09-20-2015 09:24 PM
GFTW
09-19-2015 03:52 PM
dsolis
09-17-2015 11:25 PM
chris_s
09-08-2015 03:37 PM
Quick Reply: Aftermarket shocks and struts for the G Coupe.
