Sway Bar Settings - Trying to Choose
Old 04-08-2017 | 06:19 AM
  #76
Djfarhan's Avatar
Djfarhan
anybody else have the front sway bar hitting on the oil filter?
Old 04-08-2017 | 09:12 AM
  #77
ay37's Avatar
ay37
Originally Posted by Hashim
I dont think you can buy just the rear bushings, but Hotchkiss sells a refresh kit with new from and rear bushings, should be available from most vendors That sell the bars and the price is quite reasonable
Edit: the kit is called "SPORT SWAY BAR REBUILD SERVICE KIT FOR HOTCHKIS PRODUCT KIT 22443" you can order the whole thing g from Hotchkiss directly from Hotchkiss for $25.00....before you order new bushings you may consider greasing them if you haven't already as they may just need that
Thank you Hashim!! That's what I needed.
Originally Posted by Jsolo
@v1mirage You don't accelerate into a corner. You should be entering with either the front end loaded (off the throttle), or neutral (small amount of maintenance throttle). Once you're past the apex, then you accelerate out of the turn.
Tightest settings at both ends will lead to oversteer (back end coming out). If I recall, there was a thread or link around here someplace that described how various settings at either end affected handling.
Thank you Jsolo. I've never tracked before. Typically with a decent setup and a very mild turn (almost a straight line with a slight bend), I would imagine applying power into that mild turn would produce a type of centrifugal force which gives me more "grip" if that makes any sense. I'm not studied engineer, but I imagine you wouldn't need to study it on paper to get that "feeling" in the real world. In a medium to sharp turn, absolutely, I understand you would need to ease into the turn and then power your way out of it as you exit the turn. Thanks for the advice brother.
I'm thinking to maybe soften up the rear end then and leave the front sways to the tight setting. I'll start out with that.
Old 04-08-2017 | 11:35 AM
  #78
iCrap's Avatar
iCrap
Yeah you should never accelerate into a corner.
I have an X as well and i have my rear set to the stiffest and the front set lighter. It does oversteer a little, but only if you really give it a lot of throttle.
My understanding is that if you soften the rear and have the front tigher it'll lead to the front understeering. I messed around with the settings and found the rear tighter and front looser works well.
Old 04-09-2017 | 10:53 AM
  #79
ay37's Avatar
ay37
Ya, I'd never accelerate into a corner. That's asking for a world of wrecklessness and stupid haha. I just meant that I was taking an on-ramp onto a freeway once, and it was such a mild bend (not a corner by any means), and half way onto the ramp, I started to give it light throttle while holding 3rd gear (prolly 4-5k RPM) and then the car went bonkers LOL. You should always know the limits of any vehicle you drive. That was a learning moment of the limitations of my car for sure. I'm glad I didn't hurt anyone else or myself or my beloved vehicle lol.
Old 04-11-2017 | 03:17 PM
  #80
Hikmer's Avatar
Hikmer
Was this a AWD X model or a RWD? What settings did you have on your sway bar....I absolutely LOVE cornering with the Hotchkiss bars but want to know what to avoid as I am tending to push the limits here and there....it is a heck of a lot more fun to drive...grown up go-kart for sure.
Old 04-11-2017 | 08:21 PM
  #81
RxRyanM's Avatar
RxRyanM
Bro.....
If someone can chime in for my personal situation, I'd appreciate it.
I have a 2012 X (AWD).
Hikmer (04-11-2017)
Old 10-31-2024 | 02:58 PM
  #82
Oldguydailydrvr's Avatar
Oldguydailydrvr
Hotchkiss sway bar settings 2012 Infiniti g37xs
The looser you set the rear, the less it will oversteer. The stiffer you set the rear, the more it will oversteer. I have had it set in all 3 settings. For my taste, the center setting is best. Each driver will have their own opinion of how they want it to feel, but I think a majority of the people I've seen comment chose the middle setting.
Can you tell me how different the car felt on their rear sway bar settings? I just bought a very nice 2012 Infiniti G37 xs, that is extremely twitchy especially when there is a side wind, the front sway bar is set on the loosest hole, and the rear was set on medium in the middle, I switched it all the way to the end, the loosest, and it seems to act worse as being very twitchy with any kind of side wind, any help would be greatly appreciated, recent alignment done, and new Bridgestone potenza 980 AS Plus
Old 10-31-2024 | 03:24 PM
  #83
Oldguydailydrvr
Help needed on Hotchkiss sway bar tuning
Can you help me out, I just purchased a 2012 Infiniti g37xs, it came with Hotchkiss sway bars on it and a strut Tower bar, I'm an old guy who just likes to interstate drive, and the car is extremely twitchy with any crosswind, the car has new lower control arms with alignment, and new Bridgestone potenza 980 AS Plus tires. Front sway bar is in the softest setting and rear was in the middle, I switched the rear to the softest and it seem to make it worse, any help would be greatly appreciated
dragion
02-28-2022 11:33 AM
Oakenfire
07-29-2020 02:18 AM
Philaw
02-12-2015 12:41 PM
ANMVQ
27
04-27-2012 01:55 PM
sniper27
09-16-2011 06:56 PM
Quick Reply: Sway Bar Settings - Trying to Choose
