Sway Bar Settings - Trying to Choose
Old 11-23-2011 | 06:48 PM
  #46
Dj1ofDet's Avatar
Dj1ofDet
Originally Posted by Dabo
Quick Update on the CLUNKING noise:
I put the Hotchkis Sway Bars in a few weeks ago and used the as-directed torque settings (40 ft/lbs). My mechanic friend who did the install with me actually said at that time that those torque setting weren't enough, but we followed the directions anyway. Within a week, the front nuts had come loose and I was experiencing the same clunking noise that so many up here have talked about.
We put it back on the lift and I let him torque things the way he saw fit. He brought the fronts to 90 ft/lbs and the rears to 80 ft/lbs. He also used blue lock-tight.
With the old torque settings, the parts became loose after 350 miles. I've now done 1,000 miles on the new torque settings and there's no clunking noise of any kind coming from under the car.
I'll jump up under the ride and torque away. I've been applying fresh loctite when changing my sway settings, but like your mechanic said: maybe 62 ft/lbs. isn't enough torque at all. Anyone else have feedback on this?
Old 11-28-2011 | 01:16 AM
  #47
Dj1ofDet's Avatar
Dj1ofDet
I found today that the nuts on my strut brace had backed waaaay out of spec. After re-torquing and applying loctite, the clunking has reduced significantly. I'm still gonna torque my sways past 62 ft/lbs. but I thought I'd share part of the solution to my clunking.
Old 03-21-2017 | 05:59 PM
  #48
reNeglect's Avatar
reNeglect
For hotchkis sway bar settings, people with RWD what is the ideal setting for a neutral handling in the rear?
Old 03-27-2017 | 04:37 PM
  #49
2GoRNot2G's Avatar
2GoRNot2G
Before I super charged mine I felt that the center setting was the most neutral. But ever since I installed the super charger I've gone with the softest setting (outer most hole) for the least amount of throttle induced over steer.
Old 03-27-2017 | 09:03 PM
  #50
iCrap's Avatar
iCrap
Does anyone have really bad clunking with their hotchkis bars? Its been a big problem for me these last few months. I tightened up my endlinks and it was fine for a while.... now it's clunking again. Tightened it yesterday again, still clunking.
Old 03-28-2017 | 01:18 PM
  #51
JSolo's Avatar
JSolo
Just say no!!!!!
Did you lube them well? The bushings that is.
Old 03-28-2017 | 04:48 PM
  #52
2GoRNot2G's Avatar
2GoRNot2G
Mine will clunk if the bushings need to be lubed, especially if it's been raining and they are getting wet a lot. I've started lubing them about every 5K miles and haven't had an issue with clunking since.
Old 03-28-2017 | 07:38 PM
  #53
iCrap's Avatar
iCrap
The grease fittings on my mounts have totally rusted shut....
I need to find replacements I guess. I think i prob lubed it 10,000 miles ago.
Old 03-29-2017 | 11:03 AM
  #54
Baadnewsburr's Avatar
Baadnewsburr
What kind of grease are you using? this sounds like grease washout.
For those of you with the clunking maybe try a marine grease or the hotchkis grease or the Energy suspension grease or red n' tacky or something that just keeps the bushing greased for longer...I was surprised at how fast some all purpose grease washed out on mine and caused clunking....I wish I could grease mine every 5k, but in the winter I can't get under the car often enough and I suspect my washing the undercarriage to get rid of salt doesn't help.
Old 03-30-2017 | 11:53 AM
  #55
2GoRNot2G's Avatar
2GoRNot2G
I got a tube of the Hotchkis silicone based lube for my lube gun when I got the sways, so I doubt it's grease washout. It seems that the Hotchkiss sway bar bushings have very shallow grease channels so no matter how much grease you pack in there not much stays in the bushing. Of course, the bushings on my Porsche and Jeep all seem to need to be relubed every 5K to 10K miles, so that seems to be pretty normal.
Old 03-30-2017 | 03:39 PM
  #56
Hikmer's Avatar
Hikmer
Just got mine installed today...this is a must for anyone who bought a G37 and thought it didn't handle the way it should. Middle setting seems to be where most folks are agreeing and this is how I had them installed.
Old 03-31-2017 | 12:37 PM
  #57
PandaX's Avatar
PandaX
I am interesting in getting sway bars, but I didn't know that you need to lube them. Is it necessary? I thought you just need to bolt on and it's good to go. What lube can do?
Old 03-31-2017 | 01:04 PM
  #58
Hikmer's Avatar
Hikmer
The Hotchkiss sway bars come with grease for a one time use.
Old 03-31-2017 | 06:30 PM
  #59
I've been using an small 8oz tub of Pre-lube Grease from Energy Suspension that I bought four years ago for the Eibach swaybars. At least once at year I'm at my mechanic for some kind of mod, and I always have him take down the bushings, clean and re-grease. Easy enough with the car up on a lift. Even easier, because I'm not actually doing it, LOL.
Four years and 25k miles later, and it's been working out fine. Once a year seems plenty of maintenance for this. And I've got lots of grease left in that little tub.
The Eibach bushings are also ribbed. Heck, they're probably the same ones.
2GoRNot2G (04-04-2017)
Old 04-04-2017 | 11:40 AM
  #60
Hikmer's Avatar
Hikmer
The Hotchkiss bracket have a service nipple (I know there is a better name for this but don't know it off hand) so that you can grease without removal.
Quick Reply: Sway Bar Settings - Trying to Choose
