Ordered Eibach springs, can't wait.
Old 10-22-2011, 10:33 AM
Dj1ofDet
Dj1ofDet's Avatar
Originally Posted by cy7878
It really points out that 18 inch rims are a little small for the well openings.
I will take more pics in a few weeks and remeasure the height.
So are you going to be upping your wheel size as well?
Old 10-22-2011, 11:12 AM
cy7878
cy7878's Avatar
may be when my Pilot Super Sports wear out.
Otherwise I'll just have another new set of tire sitting in the garage.
Old 10-22-2011, 12:15 PM
Locksmith
Locksmith's Avatar
Looks great man I have eibach springs too and I'm happier with it now that the springs have settled, give it some time and it'll go even a bit lower than it is now.
Old 10-23-2011, 03:07 PM
cy7878
cy7878's Avatar
Just a little update:
The car corners better because the springs are firmer and car sits lower. I can make right turns at a faster speed and not get the same tire chirps or under steer as I did before. Left wide turns are also tighter and I can go faster than before.
The freeway ride is worse, because the car kind of floats more over road undulation. I think this is because the stock dampers are not letting the car settle down with the firmer springs so the car feels more floaty/bouncy.
Old 10-27-2011, 04:23 PM
Received 4,943 Likes on 4,176 Posts
What were your alignment specs? If they couldn't get it real close to stock that may contribute to the floaty feeling your getting at speed.
Old 10-27-2011, 05:26 PM
chuckie311
Drop A Gear and Disappear
chuckie311's Avatar
looks good man i love mine dropped on the Eibachs i allready scrap going in to my garage so i cant go any lower
Old 10-27-2011, 09:57 PM
cy7878
cy7878's Avatar
So the springs did settle a bit more.
I'm at 27 in the front, 26 3/4 in the back.
My little Iphone App Clinometer is measuring my camber at -3.2 in the front (was -1.9 at the shop day 1) and -3 in the rear (-2 at the shop day 1). I'm not liking the front camber, so I may still order the front Camber arms.
Anyone care to chime in?
Old 10-27-2011, 10:15 PM
MACS
MACS's Avatar
Sorry I missed your question. I went to Lou at Amplified for the KW V3 purchase and install. I do not have a camber kit. I am at about the same height you are with 26 7/8 in front and 27 in the back, if I recall correctly. With that drop I am running -1.7 and -1.4 camber in front and -1.8 on both sides in the back.
Old 10-27-2011, 10:53 PM
cy7878
cy7878's Avatar
I'm not sure why my fronts look more inward. I'm not that low. I think I'll have the alignment checked again before spending the money on camber kits.
Thanks
Old 10-28-2011, 05:04 AM
mobe
mobe's Avatar
I ordered my eibach pro kit this week with rear cambers. I should get it next week due to the fact that I live in UAE. I was told by our local experts that I may not need front, but rear for sure. I guess every car is little different... I'll see when I get mine... Pictures will soon to follow...
Old 10-28-2011, 12:24 PM
canucklehead
canucklehead's Avatar
i had the prokit on my 6MT sedan. no camber kit necessary. alignment was back in spec except the rear camber which was out by 0.1 degree too much camber. i was fine with this, no wear issues.
Old 10-28-2011, 02:59 PM
Dj1ofDet
Dj1ofDet's Avatar
How about the camber on AWD models? OP, any solution to the ride undulation?
kavcheung
01-22-2016 02:40 PM
uzbekuz
09-08-2015 05:54 PM
mmnjtwa
09-07-2015 02:27 PM
Rick in NC
09-03-2015 11:14 PM
Quick Reply: Ordered Eibach springs, can't wait.
