Squeeky brakes and Eibachs
Hey guys....
Lately I've been hearing my brakes squeek more and more. I also have some squeeking on my Eibachs, I hear it often when I get off the car from the rear driver side.
I hardly remove my wheels so it's really dirty in there. (my car's a daily driver) Can a good cleaning do the trick? i.e. spray on brake cleaner, WD40 on the springs.
dealerships try to get the most out of stuff. one thing they like to do with rotors when they warp is sand them down.... it just gives them a shorter life span till it needs to be done again till eventually they need to be replaced
My brakes squeak pretty bad as well and i m due for resurfacing of the discs and new pad at my next service. I may be going with aftermarket discs but still undecided. that sounds is really aggravating though.
If your brakes are squealing, changing to a different pad material is probably you're only option. You should also change the rotors when you do this, and I would recommend going with an aftermarket set up for it.
Your suspension is a totally different story, and I don't know what to do about it. Maybe put some type of lubricant on it?
optikol
01-28-2016 07:31 PM
Mattimus
10-04-2015 01:33 PM
