New Rotors and Pads. Softer pedal
it's a hard brake line and it completely blocks 1 of the 2 bolts that hold the caliper in place. The only other alternative is an open ended wrench but they do not provide much torque and are not ideal in this situation. even in the FSM it specifically says remove the brake line.
Well I did it and there was a little air. It only feels a little different from how it did right before I started bleeding them. I guess the pedal started feeling better over time and bleeding just finished the job. Feels normal now. Thanks Guys.
The FSM also says to remove the battery cables before you do anything on the car but how often does that happen. I've yanked the rotors off my car without disconnecting the caliper so I know it can be done.
Did you get the Premium Dimpled and Slotted Brake Rotors or the Cross-Drilled and Slotted Brake Rotors? I was going to pull the trigger but wanted to hear from the user first! It's this or the used drilled and slotted stoptech rotors for me.
I wanted the dimpled rotors but i ended getting the drilled slotted ones. I am extremely happy with my purchase. The car stops like no other and ive noticed a slight difference in braking power after some highspeed braking so i guess that due to the good ventilation. I would definitely recommend them.
Hey Philter,
Which TSB are you quoting? I'm going to the dealer tomorrow for warped rotors... Thanks!
Paul
Paul
Did you bed in your brakes? I had my rotors and pads replaced per TSB and I had to do a few hard stops, from 60 down to 10, to bed them in pretty good before they started to have bite again.
I had to press my pedal 75% down before it started to bite. Now it bites at 25% depression and feels just like stock.
Hey Philter,
Paul
Paul
r0cketm0nkey
09-27-2015 01:34 PM
inspector94
09-08-2015 12:57 PM
