Brake squeal solved
#32
Update: After 7 months of squeal-free bliss, the squeal has returned when backing up. I'm at a loss for what the long term solution may be. I don't know if there is a design issue, brake dust build up, hardware warping, lubricant desiccation or something else. In general there does seem to be more brake pad "play" compared to other cars that I've owned.
In the next month or two, I will inspect the brakes, clean and re-lube it and see how long I can go before the squeal returns.
UCLAg37
UCLAg37
i use 3M copper anti sieze, which seems to hold up rather well between brake jobs. You might also try carlson quietglide brake hardware. Contact side is PTFE coated and the back is rubberized. They're pretty excellent at knocking out difficult brake noise
#33
i changed my front pads couple months ago. no squeal. i use stop tech pads they come with all new hardware. anyone need the old oem hardware shims etc? i still have mine if anyone want to buy it for the sport brakes
#34
Consider what the brake lubricant on the pads goes through in 7 months as far as heat cycling, exposure to the elements, brake dust and wheel cleaning chemicals. It wasn't going to last forever. This is why the factory brakes use a 2 piece shim where the brake lubricant is sandwiched between the 2 pieces. Fortunately, it's as simple as cleaning it and adding more lube.
I have a set of Carlson Quietglide hardware which I will try when my current hardware needs replacement. The Quietglide seems rather flimsy compared to the OEM hardware but I won't cast judgement on the performance until I give it a run.
UCLAg37
#35
After many months of scouring the internet boards for an answer, I should of just followed the OP! My front brakes have been squealing to the point of embarrassment. I had my pads checked a few times and there was over half of the pad remaining. I really didn't want to pay for a full brake job so I decided to just replace my front pads with Akebonos ASP1347/ASP1346. It took care for the squealing and I was happy. I couldn't leave good enough alone and decided to replace the rear pads too. Well, it start squealing! I reinstalled them a couple of times making sure I clean everything. No luck!. Then I gave it one last go and put the original shims on the Akebonos. Lo and behold the squealing has stopped. It has been one week and I hope it sticks. The reason I didn't do this at first was the Akebonos has a shim already.
For the install, I popped that one off and replaced it with the 2 OEM ones. My OCD is tempting me to do my front pads too. Go figure, they have the Akebono shims and they are squealing. For now I won't try to fix what isn't broken. Also, I lathered up the shims with Permatex 85188 Ultra Disc Brake Caliper Lube, 0.5 oz., from Amazon. I hope this helps y'all, because I am such a happy camper after so many months of searching.
#36
ashmostro
11-08-2012 06:13 PM
