Brake squeal solved
This is an ancient thread but I've been having this same issue where the brakes squeal when backing out of the garage. I've got a 2013 G37S sedan. I'm pretty sure it's never had the pads replaced since it only has 39K miles. I've been considering reapplying more brake grease on the backs of the pads because it's pretty damn loud and embarrassing.
Does anyone think adding more grease would help or is this simply something that is going to happen until I replace the pads?
Same exact thing with me and I changed and upgraded to new slotted and drilled rotors and pads. It went away for about a week but came right back.
Idk how I came to realize this but when you first start your car give it like 5 seconds and then just pump your brake like 5 or 6 times and magically the squeal is practically gone before reversing lol
I've been doing thay every morning for about 3 weeks now and it seems to work! Whenever I don't do this and forget I wake up my entire street I feel with how loud thread squeal gets its ridiculous lol
Give it a try tomorrow morning and let me know if it works for you so I can begin to spread the word lol
Krzysztof47 (05-28-2023)
I'll give it a try if my tired brain can remember in the morning... quick fix anyway so that's better than no fix at all. Seems ridiculous to have to pump your brakes to keep them from squealing. It's also weird that you're having the same problem with aftermarket brakes as I thought this was just a stock brake thing.
Thanks though.. I'll give it a shot.
I may have finally solved the brake squealing problem for my vehicle. I installed new brake hardware and applied a good coat of synthetic grease on the back of the pads where it meets the caliper piston. The loud squealing is gone now even in reverse. The only time I heard the squeal come back for a few seconds was when my car sat in the garage for almost two weeks and rust built up on the rotors.
I strongly suggest changing out the brake hardware when replacing pads and/or rotors. The hardware warps over time and I think the extra play of the pads with the older hardware without sufficient lubrication causes the squealing/squeaking.
UCLAg37
UCLAg37
Ironically, my neighbor's Nissan Pathfinder does this every morning in reverse. Used to think it was the garbage truck, LOL. I have no such issues but yeah a good dab of anti-squeal on the back of the pad does wonders with the OEM grade compounds. Running race pads on the street? Forget about it, nothing will help.
I'll live with it. I like telling people my left front brake caliper has as many pistons as all their brake calipers combined.
Idk why it makes a difference but it does. I pump mine like 6-8 times and get very very minimal squeaking and when I don't or forget to I end up waking my entire street.
#29
It's quite embarrassing. I park on the 4th floor at work and getting out of the garage going down the ramp is just bleeding my ears. If the lube thing/pumping on the brakes help, I will definitely try it.
#30
UCLAg37
UCLAg37
In the next month or two, I will inspect the brakes, clean and re-lube it and see how long I can go before the squeal returns.
UCLAg37
