What degree of camber do you run?
Old 02-26-2011, 10:18 AM
Loi
Loi's Avatar
^ when you do, let me know how it goes, I have to do mines :-)
Old 02-26-2011, 11:09 AM
Stanced370Z
Stanced370Z's Avatar
I have -3.5 front and -6.7 rear lol but it's not on a G
Old 02-26-2011, 11:21 AM
GraphiteG37S
GraphiteG37S's Avatar
On Eibachs I was running factory specs after alignment with 9.5 +35 10.5 +37 wheels. I'm lower now on JIC coilovers, with SPC rear camber kit.. I'm running like -1.6 front and within OEM spec in the rear. Factory spec if I remember correctly is between -.8 & -1.2 camber.
Old 02-26-2011, 11:42 AM
Frankyg37s
Frankyg37s's Avatar
im on eibachs and im at -1.6 witch is like stock
Old 02-26-2011, 05:57 PM
1cleanG
NextLevel Performance
1cleanG's Avatar
I would try and get between 1 and 2 and you should be perfectly fine
Old 02-26-2011, 06:00 PM
P Casey
P Casey's Avatar
Yep, exactly what I did. it sucks finding a place to do it when your car is slammed
Old 02-27-2011, 09:20 PM
1cleanG
1cleanG's Avatar
true true. Its even worse when your slammed AND have a kit of any kind. If you come prepared w/ your own blocks its not so bad :-)
vamarris
12-09-2018 11:10 AM
botlfed98
09-22-2015 12:30 PM
Quick Reply: What degree of camber do you run?
