eibach pro kit help
eibach pro kit help
hey guys, im going to get my g coupe dropped in a couple days on the eibach pro kit lowering springs. ive done a lot of searches on the forum and some say they need camber adjustments and some say they don't. im fairly new to all this so any help would be appreciated. ive heard that eibachs will wear out the tires faster than normal and was wondering what i could get to avoid this. i.e the spc alignment control arm, sway bars, spaces, or the eibach pro alignment kit? again, im pretty new to all this so any help would be appreciated. thanks!
The only reason they would wear out your tires faster is if you don't get a proper alignment. Some people have gotten away without the front/rear camber kits. I'd install the springs, take it in for an alignment after a week or so, and see how close to spec they can get things. Then you can go from there.
Ya Eibach PK you won't have a problem with. Just give it time to settle then get an alignment. It'll take a while to wear out the tires even if you don't get an alignment so no worries there. Rear camber arms could give you a more aggresive stance though if thats something you'd like
