Help Front coilover install ?
Is the mounting seal, part #2 in FSM, supposed to be reinstalled when replacing front strut assembly with a replacement coilover assembly?
Thank you in advance.
does your coilover comes complete with shock mounts?
All, thanks for the replies.
I am referring to the red gasket/software/mounting seal that is factory installed between the front shock absorber mounting bracket and the body.
I just installed a Hipermax III kit. It came with a replacement mounting seal for the rear, but nothing for the front. Therefore I assumed it wasn't necessary. Looking at my factory front struts (where the red seal remains), the question came to mind.
The kit came with shock mounts (F + R), mounting seal (R), but no mounting seal for front.
The rear also has a factory installed mounting seal, but was replaced with parts supplied with the Hipermax III kit.
Thanks again.
Thanks again.
