Review Ap racing bbk
Ap racing bbk
Hello all! i have used these AP Racing brakes for the past 4 months and all i can say is wow! it gives me a full smile every time i step on them. there were times that these brakes actually saved my @$$ from getting crushed by a semi truck who suddenly merged into my lane. i slammed on the brakes so hard that my seat belt choked the life out of me lol. AP Racing brakes is my life saver. this is the one of the best upgrade no doubt about it. can't go wrong with this setup. after using these i don't think i can ever use oem brakes again. thank you Stillen and Josh for setting me up with these beautiful brakes. i am enjoying them every time i use my car.
here's some spec's and pictures!
Front Kit - AP5700
Calipers: AP Racing 6 Piston Caliper (CP7041)
• Lightweight, pressure cast aluminum alloy 2-piece body for better pedal feel than typical monoblock calipers
• Fixed radial mount for minimal caliper flex
• Hard anodized, then finished with a tough 2-part paint system
• Differential piston bores minimize pad taper and maximize braking efficiency
• Secondary dust seals for everyday use
• Anti-Rattle clip to eliminate pad knock
Rotors: AP Racing 14.25” x 1.25” (362mm x 32mm)
• Two-piece modular rotor floats on aluminum hat
• Directionally curved vanes for maximum cooling
• Cross-drilled and slotted for aggressive pad bite and better face cooling
• Slotted only rotors optional
Brake Pads: Mintex Xtreme Motorsport Compound
• Xtremely high friction for race pad stopping power
• Excellent grip -- From cold to over 1300°F (700°C)
• Linear & predictable under all conditions
Brackets:
• Aluminum caliper mounting brackets for maximum strength and stiffness
• Anodized for durability and appearance
Brake Lines and Hardware:
• Stainless steel outer braid with PTFE inner
Rear Kit - AP3750
Calipers: AP Racing 4 Piston Caliper (CP5147)
• Hard anodized then finished with a tough 2-part paint system
Rotors: STILLEN Brake Pros Two-Piece Rotors (330mm x 25.5mm)
• Two-piece rotor design
• Retains OE parking brake function
• Stainless steel outer braid with PTFE liner (DOT compliant)
• High performance hardware included
Brackets:
• Aluminum alloy mounting
6 Piston Fronts
4 Piston Rears
Front Kit - AP5700
Brackets:
Rear Kit - AP3750
Brackets:
6 Piston Fronts
4 Piston Rears
Twins ?
I know bro ! We could be twins... LOL ! just give me a chance to decide if im going to place the order for the GTM S/C kit... payoff a loan... or buy a second hand daily driver... decisions decisions... and the money is just sitting in the account... what to do... LOL !
Looks good man, i was driving pretty hard last night and slammed on the brakes when a car from the other lane cut in front of me, and i felt the OEM brakes are dangerous for sudden brakes, it seems to not be able to brake in time. I was lucky i was downshifting at the same time. I guess need some BBK? haha... will changing out the brake pads be good enough though?
Weiboy, the AP BBK you got, do they rust? where the holes are? or did you put a zinc plating there?
not really, i look at things differently.i am happy with this product and it deserves a honest review.
yes, i have experienced the same situation as what you just described! i remember when i first bought the car back in 08 i had to slam on them and it did not do it's job and almost rear ended somebody. i never felt safe with the factory sport brakes, even tho it had a stiff pedal feel, it just does not stop in time for an emergency events. ever since i got these AP Racing and broken them in it's night and day differences. i really really happy!
the holes have some kind of special rings, paint or insert on them that prevents from rusting. i'm not too sure, maybe AP Racing Chris or Josh@Stillen can answer that question.
