Car Vibrates while braking...
Old 07-07-2011, 10:19 AM
_ant_
_ant_'s Avatar
resurfacing should fix that.
Old 08-17-2011, 08:54 AM
Xyrium
Xyrium's Avatar
Slightly older thread, but I have discovered the same issue. How would resurfacing "fix" anything? It would only be a band aid until the rotors warp again, and faster the next time since they'll be thinner after the resurfacing.
Old 08-17-2011, 09:46 AM
D_Nyholm
D_Nyholm's Avatar
100% correct.
I think I'm just going to deal with it for now. No reason to put upgraded slotted rotors on a lease. Well, at least for now:
Old 08-17-2011, 10:00 AM
Xyrium
Xyrium's Avatar
Sounds good. Someone mentioned a TSB, but no TSB number. Is there really a TSB for this? I would have thought they'd place *different* rotors on them altogether if that's the case. Please post back in this thread once you get it resolved!
Old 08-17-2011, 10:06 AM
jayjay1122
jayjay1122's Avatar
Absolutely!
I'm not even going to get into all the ways a resurface only approach is the wrong way to "fix" this issue...it is definitely just a band aid!
If rotors warp, or should I say if rotors from a specific make or model warp, especially with regularity, the problem is systemic! The equipment needs to be replaced, otherwise the conditions that caused the initial warping still exist!
Old 08-17-2011, 10:19 AM
rpm&my_G35
rpm&my_G35's Avatar
look here Knowledgebase - G Sedan - Infinitihelp.com Forums
Old 08-17-2011, 11:02 AM
D_Nyholm
D_Nyholm's Avatar
Even just a simple plastic piece that attaches to the lower control arm to direct air to the rotors would work. That is the way Porsche does it in the 911s
Old 08-17-2011, 08:51 PM
Xyrium
Xyrium's Avatar
Great, thanks.
Originally Posted by rpm&my_G35
m1cha3l
Buying & Leasing
41
03-09-2019 12:56 PM
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
m3clubracer
09-11-2016 09:01 PM
Thedbarz
33
02-09-2016 12:05 AM
350zrunnin12s
08-09-2015 09:55 PM
Quick Reply: Car Vibrates while braking...
