Project Mu has their Piston Upgrade kit out for the Akebono brakes.
*式会社プ*ジェクト・ミュー - アップグレードピストン*ット
Check out their Z34 kit which is the 370Z kit. S/ST models are same as Sport model here in the States.
That is interesting. So is the 148g to 51g weight reduction due to just using a stronger metal like titanium? I don't read the Japanese, so aside from guessing I have no clue what they're talking about.
Best guess is they used Titanium with a thinner cross section to add strength, save weight and Titanium has some better heat properties to boot. I wonder if they did anything to improve the rubber seals for added heat resistance to prevent seal failures.
Project Mu - Upgrade Piston Kit - Nengun Performance
is it really worth it? Any point of putting more money into the stock brakes instead of just getting nice lightweight 2pc brakes. I don't think those are conventional rubber seals.
Any other gain besides weight saving?
__________________
__________________
Hummmmm. Project Mu upgrade kit or bbk & rotor custom kit? Seems to me the bbk is the better way to go. Obviously significantly more than the upgrade innards but full bbk & rotor assembly is just amazing.
I guess I won't be the guinea pig to try these out first.
Google Japanese to English translation
Since lighter than steel piston that is used as a standard calipers, unsprung weight reduction of the 図Remasu. Also, wear the hard anodized giving a highly specialized lubricant, galling, seizing and suppress.
Aluminum alloy material
Piston aluminum content ( 8 Front / Rear 4 )
Pisutonshirukitto (1 ※ equivalent GENUINE)
differs depending on the caliper seal kit.
Pot and two pot rear facing only four front-facing.
Can also be used when other vehicles are diverted to support the caliper ※.
Changes in product specifications and price, and may discontinue manufacture and sale without prior notice
04G35NYC
12-24-2015 02:00 AM
