Any way to lower a X .5"? Retain stock ride?
#32
kinda seems that way.i might consider installing spacers on rears as some have done to even out gap more-that way i'll still have firmer ride and with awd ground clearance can still drive over fallen trees and road kill deer-haha.with regards to springs,lots of people on here say just get coilovers-you'll end up doing it anyway,but did i listen-noooooo! too bad the s fronts weren't just a little shorter-now,where's my hacksaw!
#33
Lee, any pics ?
Thanks as well for taking the leap! I'm also in the x-group looking for a subtle drop and had always wondered how the s-springs would turn out.
#34
not yet but check the pictures in this link.my gaps are close to this with my rears being a bit higher.will try to get some pics
Review Installed G37S coupe springs on G37X sedan!! - MyG37
#35
#36
hey guys,came across this on g35driver recently.seems the 370z front springs drop the x about 7/8".the g35s rears i installed settled a bit to about 27 3/8"(3/4"drop) with a full tank.if the 370 front springs drop to 27 1/4 that would be perfect for me.if the numbers are correct it would mean that rwd s rears and 370z fronts will give the x a 3/4-7/8" drop! will do a little more research. think i might try this when the weather warms up.i must be nuts!
check out these links-hope they work
Lowered 07 G35X and a new smile - G35Driver
370Z springs experiment - Page 19 - G35Driver
#38
#39
Don't forget, that front and rear springs should work together and they must be designed for each other. So, if you install front 370z springs only the car will feel less stable!
Please, describe your experience about RWD sedan springs (btw, they are the same for RWD and RWD S) on your AWD, as I might try to buy a set, because I cannot afford any drop in my country, but want a little bit stiffer suspension. How it takes the corners, what about riding fast/slow throght the potholes (i have really ROUGH roads in my town, like training roads for SUVS)?
As for me I've already installed RWD rear sway bar - huge difference and GTSpec front strut bar - a little less but still noticeble difference
#44
Unfortunately BC and Megan are your only options for the X. For the money they are great coilovers. Keep in mind that BC makes coilovers for Apexi and Greddy as well.
